Rosett Plasterboard Fixing
The Rosett Plasterboard Fixing is one of the easiest plasterboard fixings to use. Rosett Plasterboard Fixings can be used on drywall up to 15mm thick, you can also get Rosett Plasterboard Fixings suitable for double boarded walls. The Rosett Plasterboard Fixing is quick, easy to use and reliable. In a future video I will do a weight test to see how much weight these can hold before the plasterboard fails.
Rosett, Rosett plasterboard fixing
