Stainless steel cutting chop saw blade | Rage 2 stainless steel blade
In this video I use a dedicated blade for cutting some tough stainless-steel angle and box section. Stainless steel is much harder to cut than mild steel, especially if you use an abrasive chop saw, as it tends to get hot and burn- plus it leaves nasty burrs on the material. The Evolution stainless steel cutting blades are perfect and make cutting stainless steel very easy. In the video I was not sure if the stainless cutting blades were available for other Evolution machines, but found out at the editing stage that they are also available for the Rage 3 saws as well.
Metalworking videos
Stainless steel cutting chop saw, Rage 2 stainless
