- Ultimate Handyman Forum Index TOOL FORUM Tool Talk
- It is currently Tue Apr 08, 2025 7:17 am
Which combi drill with spirit level?
Post by wenanwhere »
Hi folks,
Can anyone recommend me a combi drill with a spirit level built in? erbauer seem to do one but not read that good reviews? I'd like a lower end makita (probably looking at second hand ones to keep the price down) but as I'm crap at drilling things straight then thought I would benefit from the level. Not looking to spend too much.
Alternatively can I just glue a bullseye or small level on the side?
thoughts welcome
cheers
Matt
thoughts welcome
cheers
Matt
wenanwhere
- big-all
- Pro Carpenter
- Has thanked: 740 times
- Been thanked: 2355 times
Re: Which combi drill with spirit level?
heeelllooo and welcome wenanwhere
a spirit level is really more off a gimmick
getting your poise right will help you drill better but to be honest a hole is a hole even a few degrees off will usually work fine as whatever you are tightening will just sit flush to the surface regardless off screw angle
a small set square can help
what exactly are the problems you are having
Half way through writing a message similar to Big All's then my internet shuts.
Screwfix seem to have a few offers on at the minute, not sure what your price range or requirements are but just a thought.
Joe92
So is that a general consensus that the spirit levels dont actually work then?
Dont want to spend more than £100 either new or secondhand really.
wenanwhere
- big-all
- Pro Carpenter
yes they work but you wouldn't chose a drill on that basis
its like choosing a car because you like the spare wheel
i recomend ryobi and they do a spirit level on some off theres
- big-all
- Pro Carpenter
this is a good deal fully compatable with the new ryobi stuff
http://www.tooled-up.com/Product.asp?PID=146394
http://uk.ryobitools.eu/one-plus-the-wo ... system.htm
ideal for diy and light to medium trade
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
I don't have one and have never used one, so I don't know, but doesn't the vibration render them fairly useless in operation..........or are they only used to find an initial starting position?
ayjay
- big-all
- Pro Carpenter
i have one on one off my ryobi drill but have never looked at it so woulnt know if it jumps but on hammer would expect that to be the case
http://www.powertoolsuk.co.uk/webcat/de ... 2M&ID=7739
- Has thanked: 833 times
- Been thanked: 3632 times
I have used a level on occasions when using my SDS to drill bigger diameter holes with accuracy. I taped one of those free Screwfix levels they gave out a few years back and although it looked stupid it worked.
- Has thanked: 77 times
- Been thanked: 335 times
I had a ryobi with a bubble.... use it on hammer and the bubble turned into 100 bubbles. Waste of space.
I'm with the above suggestion of working on your poise, use a square to help you get started straight if you dont have a natural eye for squareness.
Hitch
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1573 times
Post by Job and Knock »
Hi Matt and welcome to UHMwenanwhere wrote: I'd like a lower end makita (probably looking at second hand ones to keep the price down)
Makita don't do drills with spirit levels. The only semi-pro stuff I can think of is Ryobi (calling BA, CALLING BA!!!) who do make some of their drills with spirit levels (I used to own a corded SDS so-equipped)
Knew I should have read further....... (Some say that BA's really Ryobi's sales director in disguise.......)big-all wrote:i recomend ryobi and they do a spirit level on some off theres
As with others, though, I have to admit to the bubbles being a bit of a gimmick. Also they didn't survive all that many drops, so I can hardly recommend them
Job and Knock
- big-all
- Pro Carpenter
i know ryobi isn't every bodies cup off tea but for the diy market or someone starting out in business on a limited budget they are a godsendJob and Knock wrote:Knew I should have read further....... (Some say that BA's really Ryobi's sales director in disguise.......)big-all wrote:i recomend ryobi and they do a spirit level on some off theres
of course they wont stand up to the abuse that the trades put them through but if you cut back just a little bit they will survive for years
then as you build up you business you replace the ryobi with the big boys toys if and when they break down
- Job and Knock
Hi BAbig-all wrote:i know ryobi isn't every bodies cup off tea but for the diy market or someone starting out in business on a limited budget they are a godsend
I woz only kidding! I've worked with sparkies from a couple of firms who "buy" their apprentices Ryobi cordless drill/drivers on the grounds that they're good enough to last a few years (until they start earning proper money) and that if they don't make the grade they'll at least leave with tools good enough to either start in another trade, or keep them going at home for a lot longer. As I said before, I have owned some Ryobi stuff in the past (and my first 1/2in router 30-odd years back was actually a Ryobi R-500)
Job and Knock
- big-all
- Pro Carpenter
dont worry job n nock i took it as humour
its nice to see people "remember " some off my inane drivel
Thanks all for input. Think this seems like a very good spec for the money: http://www.screwfix.com/p/hitachi-dv18d ... 7kzcG1mh3y
Unless anyone has a better suggestion?
wenanwhere
