- It is currently Mon Apr 21, 2025 4:54 am
Change wheel audi A4
- Has thanked: 3 times
Right, this may be a silly question, but I've found a flat tyre on my audi A4 avant this morning, so I'd like to replace the wheel with the spare one.
I've lifted the vehicle, screwed out everything but the alloy wheel still wouldn't come out.
Is it just because it's an extremely cold morning or do I have to do somethingelse?
Thanks!
Thanks!
rs232
- Has thanked: 833 times
- Been thanked: 3641 times
Give it a belt, the wheels sometimes stick on to the hub and they need a shock to loosen off. Careful that you do not rock it in the jack though. A bit of wood thumped around the hub should do it.
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
thescruff
- Has thanked: 1 time
- Been thanked: 4 times
usually use copper grease BUT do not use it on the nuts/bolts; it affects their torque rating and tighten up more than they should. MOFO's to take off next time.
applying pressure to the top (as Scruff) could work; tapping the edges or "wiggling it horizontally"; if not you have to resort to smacking it from behind....
(careful with the jack and use axle stands with the spare under the raised sill)
also always check your nuts after a long drive or the next day; not unknown for them to work loose.
Raf
Hitch
Nothing to do guys. In the end I really had to call Green Flag.
The guy did it in about 25 minutes using a hammer and swearing in 7 different languages
He slightly damaged the alloy wheel (nothing serious at all), but at least I can drive now.
I couldn't see anything wrong withe the wheel itself. Do you think it's worthy try to repair it or just get a new pair? I'd say the rear ones (where the flat one was) have about 3-4mm of tread and I'm going for the MOT in 10 days.
Front one are ok as I got a new pair last year.
They are quite expensive as it's a 235/45/17/Y but to me safety first!
rs232
Sounds like it's just "fused" on to me, we used to get that a lot when i ran my garage and the customers would cringe as i walked up to their car and booted the wheel.
Copper grease is fine and it's what i always use but don't lather the whole face with it as when that stuff gets hot it goes like ball bearings under pressure and can make the wheel loose. Also as previously don't put it on the bolts as it will affect torque ratings and can make a mess later on.
At that speed rating i would probably get a new pair but there's nothing wrong with a repair if the guy knows his stuff.
Also if the repair is on the shoulder or very close to it they won't be able to repair it anyway.
If you put about 50psi in it and cover it in soapy water it will bubble where you need the repair.
Tread wise they are fine as the passable limit is 1.6mm at the mo.
Hope this helps.
Hope this helps.
Noid
- village idiot
- diesel demon
- Has thanked: 104 times
- Been thanked: 104 times
Post by village idiot »
& has been mentioned on here before, new tyres to the back
i love being married
it's great to find that one special person that you want to annoy for the rest of your life
I have a soft spot for the wife, it's a peat bog just outside Ardross
Still Yes Highland
Still Yes Highland
village idiot
Noid
Foggy
My sister once had an escort with steel wheels and I tried to remove them one day and could not as they were rusted/fused to the hubs. Even hitting them with a seldge hammer would not break them free.
Evantually I took it to the garage and they had to heat the centre of the wheels with oxy/acetylene, even then it took them ages and still struggled getting the wheels off
Noid
