Divx to Dvd
- Has thanked: 2 times
Divx to Dvd
hi
Has any one got or can recommend a good program that will convert divx to dvd.
I use a VSO divxtoDVD converter at the moment but there is sometimes a lag between the audio & video, which can get annoying at the best of times.
Any suggestions ??
Cheers Sandy
Any suggestions ??
Cheers Sandy
- Has thanked: 3 times
I use nero video converter and works fine.
The lag between video and audio can be due to an encoder problem.
In general, for this and other encoding/decoding needs I would suggest everybody to have k-lite mega installed on the system with option #7
http://www.codecguide.com/download_mega.htm
- Rich-Ando
- Pro Tradesman
- Has thanked: 135 times
- Been thanked: 304 times
if you come unstuck with getting a program, just pm me and i can send any one of a number of them that will do it easily.
i've never used this santa thing you refer to but then again, i don't need to because i have been using proggies for years to do all of this.
the only thing i would ask is why have you got this in DivX anyway? if you downloaded a film in divx and want to convert it back to dvd then it will be lossy anyway.
the loss of sync is prob also due to system handling. if yours cannot handle it well enough and you are using other resourses, it can mess up the sync. also try what rs232 has suggested.
Rich-Ando
Hi Dude
Not too sure what you men by "Lossy", prob over my head. but all i want is something to do the lot, instead of have a dozen prog's, so if you can point me in the direction of such.....then please do so. I get TV/films from mates who have downloaded them, normally they are all in Divx/Xvid, so need to convert them so they will play on my dvd. Hope you can sort me out. Cheers Sandy
Hi Dude
If it ain't broke...Leave well alone.........
- Foggy
buy a divx player ..24 quid from Asda`s
re Lossy ,look here
http://en.wikipedia.org/wiki/Lossy_compression
just means that someone has compressed it down to divx to upload it then you are converting back to Vobs (dvd format) so you will lose some of the quality
re Lossy ,look here
a great piece of software, never had issues with it- unlike when I've used Nero's equivalent in the past....MJA wrote:Like Pob I too use VSO's ConvertXtoDVD if the need arrises and have never had any issues. I like it because it's straight forward and not full of features that I never use.
can't recommend it enough. Ideal for when I copy things over from my freeview digital recorder and want to convert them to dvd format...
