hinge drill
speed
Has thanked: 35 times
Been thanked: 257 times
hinge drill
Post by speed »
hi all,
ive just orded one of these...
http://www.trend-uk.com/en/UK/product/S ... rill_.html
anyone us them? are they any good, i hope it will be perfect for fire hinges, as the apprentice cant drill central for some reason :?
tthanks jamie
chippymike
Has thanked: 16 times
Been thanked: 9 times
Post by chippymike »
yeah cant falt them, they are a good time saver for pre drilling the hinges
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
I have a set of these and they come in very useful :wink:
speed
Post by speed »
i noticed the do one for a no6 screw, are these any good for drilling handles?
if you use them for anything else other than hinges pop a list up, if they have a few uses i will get the no 6 and 8 aswell
thanks jamie
Site Admin
speed wrote:i noticed the do one for a no6 screw, are these any good for drilling handles?
thanks jamie
Not sure about that.
I have only ever used them on hinges and tubular latches.
When I fit handles I normally just use a small pilot drill, but I guess that they would work :wink:
darrenba
Has thanked: 104 times
Been thanked: 490 times
Post by darrenba »
I bought a set from Screwfix the other week and they do make fitting hinges a lot easier.
http://www.screwfix.com/prods/17166/Dri ... t-Set-3-Pc
fin
Has thanked: 32 times
Been thanked: 816 times
Post by fin »
i dont have a set but my mate does. id probably buy a set for ease. for now i just centralise the drill. but i guess if the youngun is still learning mayb its a bit hard for him
peter c
Has thanked: 6 times
Been thanked: 16 times
Post by peter c »
I have a set they are very good. If you are fitting handles you should try to move the drill bit out further by slackening off the grub screw. Should just work then.
Peter C
The end justifies the means
Return to “Tool Talk”
