Asked before but PLEASE HELP ONCE MORE lol!
cantbethathard
Post by cantbethathard »
Guys and Girls, still can't decide what to do with the walls for tiling in my bathroom. NEVER tiled before.
On the one hand was suggested I re plaster boarded on the first pic below, but as I have gone round wall in good nick apart from the adhesive left behind.
Can I "scrub, clean,sand" the adhesive off to leave a good surface? PLEASE see below this is urgent now the mrs will be going bonkers if I don't just make my mind up and start!!!!!!!
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
I'd cut a piece of plasterboard for the gap in picture 1.
Removing as much as the old adhesive will make fixing the new tiles much easier.
I have heard of people steaming the old adhesive off, but have not tried it myself. The sander should sand it smooth.
You could probably tile over the top of it all with a thick bed, but it would probably be too difficult for a novice to get them all flat.
cantbethathard
Ok thanks, I've cut the first pic out and all ready for a new piece.
Will attempt sanding the other walls and see what happens.
Also going to get a tiler in for a quote as always said I won't attempt jobs I'm not 100% confident of and I;m not to be honest. MUST have saved money stripping tiling out etc and preparing so not waste of time etc.
Now any good tilers in Somerset/Devon anyone??????
:scratch:
Site Admin
I think only-me is in your area. You could pm him :wink:
cantbethathard
Done :thumbright:
jozeffo
Has thanked: 45 times
Been thanked: 272 times
Post by jozeffo »
Rebaord the offensive bit in the first picture, then use undercoat plaster ( hardwall is preferred on this forum) to square up the rest before tiling. Make sure you PVA before plastering though
cantbethathard
Ok so does undercoat plaster go on easy or do you need to be a plasterer! I'm not lol
Also don't loads of people say don't use PVA when tiling?
EJJ150847
Has thanked: 35 times
Been thanked: 188 times
Post by EJJ150847 »
I'd talk to your plasterer first before you do what isn't required.
At least I'd reboard in Pic 1.
John
cantbethathard
Yep I've cut out and will reboard the first pic no problem.
Got a tiler coming to quote but also going to try sanding the other walls and see how smooth they come out etc.
jozeffo
Post by jozeffo »
Undercoat plaster is easy as you are only levelling up the tile adhesive. Be patient, do two coats and give it a chance to go off between coats.
PVA when tiling may be a no-no but when plastering it is often a necessity.
cantbethathard
Oh I see DOH you mean PVA under the undercoat plaster!!!!!! LOL
Sorry!
Wondering about sanding first and seeing.
Thanks all, very helpful
Only-Me
Been thanked: 3 times
Post by Only-Me »
Have you measured up how many tiles you need????
As for the rest.........tape up the door. (With you inside obviously)
And go for it with a belt sander.
The walls will need priming after that to lose the dusty feel to them. After all the dust has been cleared up first, And after the mrs has given you a bolocking for covering the house........it does get everywhere even with taped up doors :scratch:
The sill you can get away with :thumbright:
Remember......the flatter the walls........the bigger the tile. Within reason :roll:
cantbethathard
I know what you mean about the dust having sanded doors before lol!!!!!
Going for big tiles and have measured the wall area but not a clue how to convert into how many tiles so going the long way round but will get there lol.
:thumbright:
marc1106
Has thanked: 4 times
Been thanked: 49 times
Post by marc1106 »
DO NOT TILE ONTO A BACKING PLASTER if your gonna use bonding or hardwall you should get it skimmed, and remember a skim coat or a float and set wall will only carry aprox 20kg Per meter sq so check the weight on a box! before sticking em up!
Looking at them walls id patch you hole first! then scrape the old addy off with a STIFF scraper! see whats left and then skim it!
IF IT WERE EASY ITD B BORING!
marc1106
Post by marc1106 »
cantbethathard wrote:I know what you mean about the dust having sanded doors before lol!!!!!
:thumbright:
rule of thumb is measure in mm convert that to sq Metres cos you get an average of a meter per box! :thumbright:
