- It is currently Mon Apr 21, 2025 5:13 am
circular saw question
- Has thanked: 32 times
- Been thanked: 816 times
used my new circular today. but i think there may be a problem with it.
the blade isnt parallel to the shoe. ie the leading edge of the blade is closer than the trailing edge. Are all circulars like this? or has mine got a fault?
cheers
cheers
fin
- sparkydude
- Has thanked: 2 times
- Been thanked: 149 times
Post by sparkydude »
sounds like a fault to me otherwise how can you use a straight edge as a guide against the shoe if the blade is not square to it.What make of saw is it ?
Nick
Nick
sparkydude
yes i thought that and noticed something up when using it to cut a kitchen work top.
its a hitachi model number is i think c-u70 or something along those lines.
its only a few mm but i guess its too much to use again.
maybe i should take it back to wickes and see what they say. i bought it in december so still got loadsa guarantee left
fin
- sparkydude
Unusual to find it in a well known brand, but as you have shown not imposssible. Have you made sure the blade is straight, and that it is seated correctly on the saw itself, try taking it off and re fitting it to see if that makes any difference.
Nick
Nick
sparkydude
fin
- Has thanked: 77 times
- Been thanked: 335 times
Just measured mine, its a fraction out, not even 0.5mm. (Mines a C7SB2)
I gather none of the brackets are bent? When the blade is at minimum depth the bar does allow it to move a mm or so, but is ridgid at maximum cut.
Hitch
fin
fin
- Has thanked: 740 times
- Been thanked: 2356 times
no not realy because it means the back off the saw blade has more work to do as cutting with the blunt back off the teeth causes more frictionfin wrote:ok i had another check, maybe 2 mm out. is that an acceptable amount?
although the riving knife will fight to pull the blade into the slot cut by the front off the blade this will make it difficult to hold the base against a strait edge or the fence
i would say 1mm would be ok but not 2mm
- Has thanked: 833 times
- Been thanked: 3641 times
Have a close look at the screws holding the shoe on. Sometimes the holes are slightly elongated to allow for truing up. If not you may be able to enlarge the holes for this purpose.
fin
Id think it would be worse on a battery tool, much less cutting per charge, due to the extra drag.
I dont know if it has the same base setup as mine Fin, the only way adjustment could be got is by reming the bracket on the trailing end, and tapping it either direction slightly.
Hitch
