- It is currently Mon Apr 21, 2025 2:25 am
Grinding noise from engine compartment
Hi all any advice would be greatly appreciated.
My 2001 vw passat has developed a grinding noise, this only happened when I shut the bonet last night, its as if something is catching somewhere, when i put pressure on the bonnet were the catch mechanism is the gringing starts or when I brake hard, I have checked the fan and nothing seems to be catching It only happened after opening the bonnet, it also starts as son as I pull the bonnet release.
any help appreciated.
Neil1974
- Deleted-user-3
- BANNED
- Has thanked: 101 times
- Been thanked: 157 times
Post by Deleted-user-3 »
i'd be looking around the timing cover, alternator / powersteering belts / pulleys or if the fan is running.. round the fan...
other than that there isnt a load more that moves, not that you can affect by slamming the bonnet anyway?
definately a grind not a rattle then?
sure you havent left a spanner in there somewhere? i probably would
Deleted-user-3
Neil1974
- Deleted-user-3
- BANNED
you havent lost a bolt off the bonnet catch have you and its sitting on the cross member bit between the rad and the grill?
sommats either loose or fell in where it shouldnt..
id be poking and prodding with a screwdriver till i either found it or broke something else
one of those 'anchor' nuts that clip over the edge of sheet steel? usually found near the rad / fan... if a bolts fell out it'll be loose..
dunno mate, try a torch on the job?
Deleted-user-3
Neil1974
mikew1972
Neil1974
- Deleted-user-3
- BANNED
guessing its the bonnet release cable come out of its clips and rattling against something? pressing the mechanism would loosen it up?
dunno bout hard breaking though? maybe if you find a part of the cable where you can get your hand on it as its threaded through the wing (or wherever it goes) and pull on it, see if it changes or stops?
maybe its dropped down from its usual route and ended up down by the crank pulley or power steering pump right down the bottom, only the vibration is only picked up on the bodywork?
Deleted-user-3
