Damp on chimney walls
hi all, can anyone help please. We have damp problems on the bedroom walls where the chimney's are, It's a detatched house with the chimney breasts at either end and are both external, ie flat walls inside. None of the flues are in use and are all capped off. I've read several posts about having a ventilation flow through the chimney flues, although this may cure the problem I'm thinking of re-roofing the house soon, and possibly taking the chimney stacks down to roof level and tiling over them, If I filled the flues with insulation (rockwool or similar) to my way of thinking this would prevent the warm air internally condensating on the cold chimney walls. Has anyone done this or is it a bad idea ?. The house is about 60 yrs old and has cavity walls which have been insulated, where the chimneys are its only one skin of bricks between the internal wall and the flue. Thanks for any help
