- Ultimate Handyman Forum Index TOOL FORUM Power Tool Reviews Hikoki/Hitachi
- It is currently Thu Apr 03, 2025 6:49 pm
Hitachi DV18DVC/JK Cordless Combi Drill and Torch
Hikoki/Hitachi power tool reviews in here please
I have seen this drill in B&Q for £99.99.
[color=#FF0000]Dead link removed by admin[/color]
The fact that it comes with 3 batteries is good, but is the drill any good? Will it go through masonry with relative ease, and not break after 6 months? Are Hitachi a well respected brand of tools by tradesmen?
mrx01
- Has thanked: 11 times
- Been thanked: 110 times
I've had one of these kits for about 6 months. (thanks UHM) I would normally buy cheaper drills as its always the batteries that let me down after about 2 years of fairly heavy but infrequent use. (tend to use them loads for a week or 2 then not for a month)
I have to say it is the best battery drill I have had, physically smaller than other 18v drills I have had but just as powerful. 3 Batteries is great, 1 in use, 1 cooling down after charging and 1 on charge.
Don't use the torch much but it does come in handy from time to time.
My only criticism is that the torch, 3 batteries, the drill and the charger will not all fit in the hard case as supplied, however, with just a bit of trimming with a stanley knife on the inside it will and there is stil room for a dozen drill bits and a set of drivers.
Mike
mikew1972
mrx01
Very few non-SDS battery drills are much good in masonary. A non-SDS mains drill will always be better than a non-SDS battery drill.
It will do the occasional hole in masonary where thee is no mains conviniently available. Buy good quality masonary bits to make the most of the drill if this is what you want it for.
Mike
mikew1972
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
I was going to write a review of this drill/torch after I won one on here a few weeks ago!
Now it's been tested for a while I would have to say it's excellent
Almost as powerful as my 24V bosch (admittedly a couple of years old) it's nice and light makes an excellent screwdriver once you throw away the supplied bit (same as any make).
The torch is very good and seems to last about 3 hours on a single charge.
No percussion drill is going to match an sds drill in masonry but an sds is no good as a screwdriver
You can get decent masonry drill bits up to about 7mm for these drills that are ok in most substrates except concrete.
Is it worth the money? Well mines found a permanent place in my already crowded van.
Razor
- xALFAx
I've the 14.4V one with 2 batteries and the torch, and have been using the 18V one over the last few weeks as well.
I wouldn't be using the 18V for any masonry stuff but other than that i've no hassle with either one.
The torch is great for taking the last dregs out of the battery before re-charging to keep its life up!!!
Still stick to the wired drills for masonry though
xALFAx
- Has thanked: 740 times
- Been thanked: 2355 times
my only real comments would be
3 1.4 ah batteries are equivilent to 2 medium powerd batteries at 2.1ah
having said that that is good value and i would buy it
and as a operational tip always take the battery from the torch to use in the drill and replace the battery in the torch never bypass the torch then this will keep your batteries in peak condition as the torch is low consumption and sporadic use once the novelty has worn off lol
- These users thanked the author big-all for the post:
- barry_morgan
- dave.m
- Deceased 07-06-2012 R.I.P
- Has thanked: 13 times
- Been thanked: 318 times
Re: Hitachi DV18DVC/JK Cordless Combi Drill and Torch
Barry,
Don't be disappointed but the OP was posting about it in December 2009 and it is not on the B&Q website any longer.
dave
dave
But you cannot tell him much.
dave.m
Screwfix have a twin pack with Li-ion for £50 more-
http://www.screwfix.com/prods/25400/Pow ... ill-Driver
- Razor
I won mine as a prize on here almost a year ago.
It's been hammered everyday and it still works although I would expect the batteries to struggle a bit when it gets cold this year and start loosing charge overnight in the van.
For the average diyer it's almost indestructible!!!
Cheers UHM
Cheers UHM
Razor
