what is best to use to prepare plywood for tileing
Alice
Has thanked: 109 times
Been thanked: 20 times
Post by Alice »
can you please tell me what best products to use ,i have removed previous tiles,its an electric shower over bath wall,and due to budget i do the diy ,but dont mind paying that bit extra for the proper materials any help very much appreciated.
thankyou! :-)
aileenynwa :cheers:
Rookery
Been thanked: 19 times
Re: what is best to use to prepare plywood for tileing
Post by Rookery »
I wouldnt use plywood. I would use Aquapanel or Hardiebacker instead. If you must use ply, it should be min 15mm thick, WBP or marine, sealed on the reverse side and edges with SBR primer and screwed to a stable substrate.
Alice
Post by Alice »
Rookery wrote:I wouldnt use plywood. I would use Aquapanel or Hardiebacker instead. If you must use ply, it should be min 15mm thick, WBP or marine, sealed on the reverse side and edges with SBR primer and screwed to a stable substrate.
thanks for the reply Rookery,hope this dont sound daft but what is SBR, also what do you think of bal products. And i love diy (no option really) but im just learning about foroum and computing as i go along! :oops: so thanks again :-)
Rookery
Post by Rookery »
SBR is a priming/bonding product. BAL Bond is one such. BAL is good quality gear although a little expensive.
These users thanked the author Rookery for the post:
Alice
tictic
Has thanked: 5 times
Been thanked: 23 times
Post by tictic »
as above for boarding your "wet area" use a 12.5mm cement based backerboard fitted to mfr instructions,then for rest of walls use a 12.5mm plasterboard...will last a lot longer than WBP PLY onto your walls.. :thumbright:
These users thanked the author tictic for the post:
Alice
