FINALLY GOT A ROUTER!
Locked
DIYER77
Has thanked: 2 times
Post by DIYER77 »
I took your advice from my previous posts about 'which router' and have got myself a 2nd hand Makita 3612C 1/2" for a bargain price. After reading some good reviews I'm happy with my purchase and just need to get myself a 30mm guide bush for it. Is there a standard one for this model? All I wanted to ask was for any of you that use this router or have used it in the past, which speed setting (1-5) is best for cutting worktop. 40mm laminate. :scratch: :dunno:
darrenba
Has thanked: 104 times
Been thanked: 490 times
Re: FINALLY GOT A ROUTER!
Post by darrenba »
speed
Has thanked: 35 times
Been thanked: 257 times
Post by speed »
i use speed 2 and cut 6mm per pass keeps heat out of the cutter
ive seen people do highspeed and 10mm per pass and after 1 joint the cutter is blunt/burned
get some scrap and do alittle practicing to see what suits you
Colour Republic
Has thanked: 263 times
Been thanked: 544 times
Post by Colour Republic »
Either get some cheap bits a throw after every other joint, or get some decenct ones and spray with PTFE every now and again whilst cutting extends the life quite a bit.
I thought you said in your other post you had a trend multi-base? that comes with a 30mm guide bush if I remember rightly :scratch:
DIYER77
Post by DIYER77 »
Thanks for the help and advice. No, I haven't got a trend multibase. I may have suggested possibly getting one though in previous posts. :cheers:
fin
Has thanked: 32 times
Been thanked: 807 times
Post by fin »
those trend multi bases are awkward. and i find the cutter is right on the limit on my router for cutting work tops.
ill be buying a makita guide bush for mine. its london sent trend guide bushes but they are to small to fit into the base
Locked
Return to “Kitchen Fitting”
