Kitchen carcasses
- zedhead
- Has thanked: 64 times
- Been thanked: 19 times
Kitchen carcasses
Hi and thanks for looking, Where is the best place to get bare carcasses from these days, I need 900 high wall units which narrows it down a bit. I have Howdens local but wondered if there were other options, before I start haggling with them.
Cheers
Baza
Cheers
Baza
Baza
- root
- Has thanked: 168 times
- Been thanked: 173 times
Re: Kitchen carcasses
oh i am sure the OP means 900mm high wall units, there was a post a while back
900mm-kitchen-wall-units-would-be-a-lif ... 45265.html
- Dave
- zedhead
Yep I meant 900mm high wall units, as I am refurbishing an old house with high ceilings and don't want a huge space above them. thank you for pointer at the other post root.
I was originally going to make the wall units but thought if I can buy them it may be more cost effective
Baza
- Has thanked: 3 times
- Been thanked: 8 times
ormerods do them in their range.. find a local supplier to you .. google ormerods and you will get a contact number, they can then give yu any outlets near you
- zedhead
Thank you, will look it up today.Loosenup wrote:ormerods do them in their range.. find a local supplier to you .. google ormerods and you will get a contact number, they can then give yu any outlets near you
Regards
Baza
Baza
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1573 times
Ormerods = J & J Ormerod, these days they're called JJO plc. I should know them as their lorries are sometimes referred to round here as the "yellow peril"! (come up to one down a narrow road and you'll know what I mean) If you're up in Lancashire they have a retail showroom called "Rossendale Interiors" in the middle of Stacksteads (half way between Rawtenstall and Bacup)
- zedhead
- zedhead
Cheers for that... I got em from howdens in the end.Job and Knock wrote:Ormerods = J & J Ormerod, these days they're called JJO plc. I should know them as their lorries are sometimes referred to round here as the "yellow peril"! (come up to one down a narrow road and you'll know what I mean) If you're up in Lancashire they have a retail showroom called "Rossendale Interiors" in the middle of Stacksteads (half way between Rawtenstall and Bacup)
baza
Baza
