USB FLASH DRIVE CONFIGURATION
- Has thanked: 66 times
- Been thanked: 3 times
When I use my Verbatim 4 GB Flash Drive there is no problem,but when I plugged in a new Sandisk 64 GB Flash Drive it was not recognised,even though a driver was downloaded for it.What am I doing wrong?.
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
Re: USB FLASH DRIVE CONFIGURATION
Try leaving it in the USB socket for longer..... I've found that the larger the device, the longer the PC seems to take to recognise it.
Failing that you need to go into start/control panel/administrative tools/computer management and see if the device is 'there' and then 'mount' it (right click on the device - if it's shown - and allocate it a drive letter).
- Has thanked: 47 times
- Been thanked: 2579 times
Just wondering have you got USB 1 or USB 2, also can you try it in another pc?
- kellys_eye
Could be a dodgy device - where did you purchase it? many of the higher capacity devices have lots of 'fakes' on the market and eBay are a sad source of too many of them. They've even been reported outside of eBay so if you purchased it through a regular source then look for an exchange under warranty.
Bought it from PC World and it was tested in store.Someone told me that my computer is configured for the Verbatim 4 GB Flash Drive and to make the new one work that will have to be configured to my computer,but I don't know how to do that.
- kellys_eye
- Cannyfixit
- Has thanked: 102 times
- Been thanked: 183 times
- These users thanked the author Cannyfixit for the post:
- mhow
- kellys_eye
Is the drive USB3 (as opposed to USB2)? There are many reports for USB3 not working (backwards compatibility) with USB2 ports even though they are supposed to be ok.
The icon for the new USB is showing and my computer,which is a Toshiba Satellite Pro L300-1FK,downloaded a driver for it and that is as far as it goes.
P.S
Running Windows 7 Home Premium
P.S
That address Cannyfixit gave me may just be the solution.When I first had a look at it I failed to understand what it was about but when eventually it percolated through my thick skull it dawned on me that the new usb was using the same letter F as the old usb.When I have a bit of time available will give it a try and let you know how I fared.Sorry for being so long in replying.
- kellys_eye
Drive letters are allocated as they are made available and removing one thumb drive and replacing it with another 'should' just reallocate the original drive letter i.e. any time you stick a USB key in it will appear as 'F' - if you stick TWO devices in they will be F and G. It is unusual for individual USB sticks to have a 'fixed' drive letter.....
- kellys_eye
Just a thought - plug in the 4Gb device and then BEFORE YOU REMOVE IT, right-click on the USB icon in the task bar and select 'safely remove USB device' (unless you already do this of course - not many people do!). If the drive letter is 'fixed' then doing this should delete it's setting and allow another device to be allocated to it.
Thanks,but I do religiously click on eject before removing any plugin.What baffles me is that the usb shows in computer and disk management but when I try to download files to it when it is plugged in it only shows the designation lettter of the old usb and says:-Disconnected.
