Occasionally PC bootup at windows freezes computer?
amdk62
Post by amdk62 »
Hi, I'm running Vista, I recently upgrade my pc to duo core (intel). Previously, running E2140 (1.6GHz) and had a new fresh installation of Vista - it runs perfectly without any hitches. But within a couple of weeks later having seen the price drop in pc components, I decided to changed the memory and CPU (1.8Ghz now), now this problem arises. The problem only occurs occasionally (but still a problem) - it boots upto opening of desktop screen and then freezes, the mouse cursor still manoeverable, the rest just freezes. Any ideas pls?
Hoovie
Borders Bodger
Been thanked: 4 times
Post by Hoovie »
I would suspect faulty RAM.
Had a similar problem when I added a 1GB module to wifes laptop - crashed or hung at random, took out RAM - ok, put it back in, hung again
And the RAM passed all the tests I could find as well. Sent it back, got a new module, fitted it, no problems since :thumbright:
Tricky to fix if random:
Put back the old processor OR the old RAM and see what happens.
... If ok for a while, probably whatever you upgraded and is now on shelf,
... If hangs, swap them round again and see if it hangs.
Then send back whatever was out of the system when it worked without a hitch :thumbright:
Foggy
Post by Foggy »
would suspect ram also but could be cpu and heat related ,what temps have you got ?
do as Hoovie says tho ,replace and see what happens
amdk62
Post by amdk62 »
Hi, yeah I think it's probably the ram as it was pretty cheap when I got it. But last night I decided to see what bios option are for ram on my mobo, it seem i can adjust speed and timing, so set that to auto speed - so far (touch wood) it's running without any hitch.
Refering to CPU heat temperature, it running fine at around 25-35oC
Hoovie
Borders Bodger
Post by Hoovie »
nice one :thumbright:
25-35C is a very healthy temp, if things haven't changed too much from when I used to deal with that kind of thing
amdk62
Post by amdk62 »
Yeah I know the feeling, its those power machine that required lots 3D powers ie, gaming rigs that hype up those temp.
It seem my pc is stable again now, having test the bootup process several times today and with no hitches.
So thanks again for your replies.
Foggy
Post by Foggy »
glad its ok
so did you leave the new ram in or change back to old stuff
unclek
Post by unclek »
If you want to test your memory download this...
http://www.memtest86.com/
(go to free download)
Hoovie
Borders Bodger
Post by Hoovie »
unclek wrote:If you want to test your memory download this...
FWIW, I used that on some memory I bought for a laptop - ran overinght without a problem - unlike Windows with the RAM :cussing:
they are worth a go but don't always pickup the problem.
amdk62
Post by amdk62 »
No I left it as it is, just change the speed & timing.
Return to “Computers”
