Seagate backup plus 4TB review
Seagate backup plus review
I have had a couple of backup drives over the years, I regard them as being important just in case the inevitable happens and a hard drive fails on the computer. Because of the large amount of HD video footage that I capture the hard drives tend to get full very quickly.
I bought the Seagate Backup plus 4TB several months ago. I need 4TB because the main drive for the computer is a 500GB SSD and then I have two 1TB hard drives configured in raid 0 which equals 2.5TB I figured I’d get one that is plenty large enough rather than struggling with a smaller drive.
You will never know how good a backup is until you need it, hopefully I never will need it and I’m not confident it would ever work judging by the reliability of the software used to do the backup. Since installing the drive I have had nothing but problems with my computer. At times the computer runs so slow that you cannot even use it and since installing the software the reset button on the computer has never been pressed so many times- which I am certain is not good for the computer!
A few weeks ago I took some data from a large hard drive and so I used the 4TB external hard drive, which was unplugged and lent to a friend for about a month. I uninstalled the Seagate Backup plus software and in that time the computer worked brilliantly, I never hit the reset button once in all that time and I never got the mouse pointer doing its “busy” motion like I regularly get now.
Another thing that used to annoy me was the fact that the software was set up to continuously back up my computer, so I would expect it to have one large backup file that would be the same size as the data on C drive and F drive combined (which is what it is set to backup). Bearing in mind that the backup drive is 4TB I would expect there to be plenty of room, but for some strange reason I kept getting a message that said “Drive 90% is full”. That’s not a miss type by the way, it actually says “Drive 90% is full” not “Drive is 90% full”. I’m wondering if this software has been written in another language and has not been translated correctly!
So how do you get a 4TB drive to be 90% full when you only have 2.5TB (maximum) data on your computer? Well it’s easy because the Software seems to have backed up the entire computer to begin with and now is making another backup each day, so it’s not adding to the original file and altering things that are changed, instead it’s writing a new file each day!
After I got the drive back from my friend I wiped all the Data and then reinstalled the latest version of Seagate backup, thinking that they must have fixed the bugs in the software but I was wrong. It’s still slows the computer down to a snail’s pace and is still showing the “drive 90% is full” message when I boot up the computer.
So if you are thinking of spending your money on one of these backup drives I would not bother using the software that is supplied with it, unless you like having a slow computer. I’m now going to format the drive and use the backup function in Windows 7 to see if that is any better.
The drive itself is perfectly fine; it’s just the software that makes it unusable!
- These users thanked the author ultimatehandyman for the post (total 2):
- gas4you • kellys_eye
- Rating: 14.29%
