Ceiling light with a pull cord switch.
Locked
Baz and Teen
Post by Baz and Teen »
Hi can anyone help with how to install a ceiling light with the old colours,the pull cord has the old colours,but the new light fitting has the new colours. :?
Many Thanks Baz and Teen
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
Hi and welcome to UHM,
Have you seen these pages on the main site?
http://www.ultimatehandyman.co.uk/diy/e ... /index.htm
http://www.ultimatehandyman.co.uk/diy/e ... wiring.htm
It should be pretty simple-
old colours.........new colours
RED...................BROWN
BLACK................BLUE
Baz and Teen
ultimatehandyman wrote:Hi and welcome to UHM,
Thanks but done all that and light was fine yesterday but when we pulled the switch to go off it keeps tripping the circuit breaker for lights.!!
Site Admin
Can you tell us what wires you have at the ceiling rose and what wires you have in your new light?
If possible some pictures would be a great help.
Baz and Teen
Black/red/Earth in rose,same in wire for pull switch.....and blue/brown and earth in light
Site Admin
do you just have one red, one black and one earth in the rose?
Are none of the wires wrapped in insulation tape?
Baz and Teen
ultimatehandyman wrote:do you just have one red, one black and one earth in the rose?
Picture of wires in the ceiling,2 red 2 black 2 earth(green cover)
Site Admin
At the pull cord switch which terminals are the wires in?
Baz and Teen
ultimatehandyman wrote:At the pull cord switch which terminals are the wires in?
The wires havent been touched from whoever installed the pull switch in the past,so have taken a picture,cant really get to see much at the moment without pulling it right out.
Think will have to give up til tomorrow :scratch:
Site Admin
It is probably wired like this-
So connect the two reds together in a terminal connector and then put one black that looks like it comes from the pull cord switch to the brown on the new fitting and wrap the wire with red tape and then put the other black wire to the blue wire on the new fitting and it should work.
Baz and Teen
Thanks for that problem resolved.
Locked
Return to “Lighting”
