Hi all
I have a job lot of x60 tubes of CT1. x40 White and x20 Clear. These are the new style with the red/green Eco Compliant sign in the top corner of the tube.
Price = £400
The listing is for all 60 tubes and works out to £6.67 per tube, which is very good value. However, if you require less please get in touch to discuss your needs and I can get back to you with a price.
I'm in North Norfolk (often in Norwich too). Also happy to post. Get in touch to discuss.
Thanks for looking and let me know if you have any other questions.
Cheers
CT1 Sealant & Adhesive. Silicone. White & Clear. Job Lot x60
- Has thanked: 159 times
- Been thanked: 17 times
Re: CT1 Sealant & Adhesive. Silicone. White & Clear. Job Lot
Also, forgot to add, I have a few cans of MultiSolve as well.... This is also made by C-Tec. It's a multi purpose solvent for the removal of adhesives, sealants, oil, grease. silicon, and a whole lot more.
Can also be used with CT1... A spray from this makes the CT1 much easier to work with and tool.
They are the smaller 200ml cans and the price is £6 per can if bought singularly. If bought in larger quantities and/or with tubes of CT1, then I can work out a discounted price.
Cheers
Cheers
