- It is currently Sun Apr 13, 2025 4:34 am
Help! I can't remove a chisel bit from my parkside SDS drill
- Has thanked: 285 times
- Been thanked: 403 times
Post by London mike 61 »
As the title says, it's stuck and I only did about half an hours worth of chiselling.
This is the first SDS drill I've ever owned so not very experienced with it yet, anyway I put the bit in the chuck as described in the instructions by pulling the collar back and it went in OK .
To remove it I pulled the collar back but it won't release the bit .
I would greatly appreciate any help and advice
Thank you
Mike
Thank you
Mike
London mike 61
- Has thanked: 740 times
- Been thanked: 2355 times
Re: Help! I can't remove a chisel bit from my parkside SDS d
if the collar has a cover maybe you just sliding the cover back
so try gripping the cover tightly to grip the collar underneath
- These users thanked the author big-all for the post:
- London mike 61
The collar slides back all the way and I've tried gripping the dust cover that the bit slides into and pulling but it won't release.
Is this sort of thing quite common or are some drills more prone than others?
Mike
Mike
London mike 61
i dont use sds in general
i had a challenge one as it was only £35 used it on a few jobs then gave it away to a builder starting up in business
and it happened to it wasnt till i removed the dust cover that i worked it out
looked like this one
https://duckduckgo.com/?q=challenge+sds ... ll-kit.jpg
Thank you big all for your comments, I really want to get to like using the drill and maybe in time I will learn all the nuances of these machines but at the moment I'm finding it hard to be positive about the drill if every time I use it I have to faff around changing bits!
There has to be a simple solution to getting the bits in and out easily, I just need to be guided in the right direction.
Mike
Mike
London mike 61
- Has thanked: 1415 times
- Been thanked: 4031 times
Did you use any grease/lubricant before inserting the drill bit/chisel ??
- These users thanked the author wine~o for the post:
- London mike 61
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Is that how the instructions say to do it?London mike 61 wrote: To remove it I pulled the collar back but it won't release the bit .
Mine is a different method, (and not a Parkside) but it might be worth a try: to insert a bit, that's all I do, just insert it - to remove a bit I have to turn the chuck slightly (anticlockwise, viewed from the pointy end of the bit) and pull it out.
- These users thanked the author ayjay for the post:
- London mike 61
ayjay
wine~o wrote:Did you use any grease/lubricant before inserting the drill bit/chisel ??
No mate , there was no mention in the instructions so I didn't bother, should I have ? If so where would you apply the grease!
Mike
London mike 61
ayjay wrote:Is that how the instructions say to do it?London mike 61 wrote: To remove it I pulled the collar back but it won't release the bit .
I don't seem to be able to turn the chuck at all and from what I have read is that the bits are generally held in place by a ball bearing system. I've tried tipping the chuck down and also had it pointing up in case it makes a difference but alas so far no joy.
Mike
London mike 61
I'm surprised. They used to come with a small amount of grease.. just a bit applied to the end of the chisel bit stops it from forming a "Mushroom head" on the bit.. which can make it impossible to remove..London mike 61 wrote:wine~o wrote:Did you use any grease/lubricant before inserting the drill bit/chisel ??
Of course the good news is that you have kept the receipt.... and have a 3 year guarantee......
All SDS drills need some sorta lubrication (Sfaia)
- London mike 61
- ayjay
Just a little dab on the fat end of the bit.London mike 61 wrote:wine~o wrote:Did you use any grease/lubricant before inserting the drill bit/chisel ??
Mike
I keep an old 35mm film canister with grease in it in the drill box.
It was only half full when I put it in there twenty years ago and it's almost empty now - you don't need a lot.
- London mike 61
ayjay
Well if I can get the bloody thing out I will certainly put a dab of grease on the bit before I insert it but it looks like I'll just have to keep trying different things until it pops out .
Mike
Mike
London mike 61
- Has thanked: 126 times
- Been thanked: 1045 times
I keep a little tupperware of grease in the box of my workzone (aldi) SDS, before putting the bit in I dunk it in the grease, never had a problem removing bits even after hours of chiselling concrete.
- These users thanked the author Rorschach for the post:
- London mike 61
Rorschach
- Argyll
- Has thanked: 1194 times
- Been thanked: 584 times
I use a Bosch 36V cordless almost every day. From time to time the SDS bit does get stuck. The last time it happened I had to jam the bit in a vice and use my body weight to pull the drill. It always comes out eventually.
- These users thanked the author Argyll for the post:
- London mike 61
Argyll
- Cannyfixit
- Has thanked: 102 times
- Been thanked: 183 times
Post by Cannyfixit »
Same as with my 36v Bosch,even though i always grease the bits,find it happens more when using bigger bits like my 16mm,Argyll wrote:I use a Bosch 36V cordless almost every day. From time to time the SDS bit does get stuck. The last time it happened I had to jam the bit in a vice and use my body weight to pull the drill. It always comes out eventually.
- These users thanked the author Cannyfixit for the post:
- London mike 61
Cannyfixit
