This is not acceptable, the level of the top step should be 2 Brick courses below the top step surface (ie: 150mm)
davyp1[/quote]
Did you mean the level of the DPC should be 150mm below the top step surface? As I am a little confused now after you said 'the level of the top step should be 150mm below the top step surface'...
