Rescue mobile phone from behind fitted wall units
Jo1
Has thanked: 2 times
Post by Jo1 »
Help my son managed to drop my mobile down the small gap between my fitted Cupboard and the wall
. The cupboard is part of a run with cornice top and bottom, and the walls are tricky to fit to ( old brick/ plaster and prone to being crumbly) so I’m hoping to avoid having to remove cupboards
Does anyone have any ideas? Is it feasible to cut through the back with a Stanley knife?
Rorschach
Has thanked: 126 times
Been thanked: 1045 times
Re: Rescue mobile phone from behind fitted wall units
Post by Rorschach »
If it's a hardboard back then a stanley knife will cut it eventually. Take your time though and make it neat, then it will be easier to repair later. Make the cut at an angle too, then the piece will not fall through the back.
Jo1
Post by Jo1 »
Thanks I’ll give it a try, think the back is hardboard, fingers crossed
toolbox
Has thanked: 131 times
Been thanked: 217 times
Post by toolbox »
Cutting hard board with a stanley do it in stages take a light scribe first going slightly deeper each time.
These users thanked the author toolbox for the post:
Jo1
Has thanked: 833 times
Been thanked: 3633 times
Is this a base unit or a wall unit? If it is a base unit then it will be easier to pull the kick board off as they are usually held on by clips. If it is a wall unit then as the others have said above. How the hell did he get up there to drop a phone??
OnlineOnline
Jo1
Post by Jo1 »
What can I say, he’s a 10 yr old adventurous climber, with Autism and learning difficulties, and I need eyes in the back of my head!!
Well it was quite an achievement to get up there! I can see now how it happened. Good luck with retrieving your phone :thumbright:
Jo1
OnlineOnline
Has thanked: 740 times
Been thanked: 2355 times
just a though
some units can have batons going side to side which may or may not catch the phone
try ringing it to help locate its exact position :dunno:
Job and Knock
Old School Chippie
Has thanked: 742 times
Been thanked: 1573 times
Post by Job and Knock »
I presume you mean split battens or (French) cleats. If that is the case the phone would be fairly near the top as you always need to put the top cleat in where it would support the weight. Upper cabinets only, though, I'd say
Return to “Kitchen Fitting”
