Sealey VS8650/ Autel EU702 Software update file for Vauxhall
Hi there, can somebody send me a software update for Sealey VS8650 or Autel EU702 ( older version not MaxiDiag) try to find on the net but unsuccesful, if anybody has got ( or had ) one of this scanner and still have downloaded update please send me file to my email.
- Has thanked: 105 times
- Been thanked: 878 times
Re: Sealey VS8650/ Autel EU702 Software update file for Vaux
you have to update the sd card in the autel software on a pc, I only have the Maxi Das and Maxi Check pro
http://support.autel.com/support/home
what are you trying to do ? what model, year and engine ?
Well that's the problem, Autel does not support this any more, this is actually Sealey, but is made by Autel, it's same model as MaxiDiag EU702 ( did serch on net it is MaxiDiag) Autel as most american businesses, supports their products for two years only, then need to replace old product for a newer one , this is few years old so there is no support either on Sealey or Autel. I need to test and then change VIN number in rear fuse box, which I think I need to change. It's Vauxhall Astra 1.4 SXI 2006, engine Z14XEP, the software I have with the tool doesn't have this engine number, so can't connect to ECU. for this year and this model it only has 1.8 and 1.9 enginees.
Well you cant do the vin change with a low end scan tool (most tools under £600 will not do bi directional coms) - you can with a tech2/clone or a VX Diag (GM), 2006 makes it a Astra H iirc that should be in the bcm if so you will need access tis2web and the software downloads for your VIN and re-flash it
manually select the car with the autel and select it as a Corsa that will read the ecu and bcm
iirc autel is a Chinese company the same as launch
