arrogantowl wrote:Hi there, i have just got a 24v Bosch drill from screwfix which came with 2 batteries Model number (Bosch PSB24VE2 Combi Drill 24V)
M
Nice Drill 24V but I have to ask why such a beastie when you don't use it so often? Still a nice piece of kit.
arrogantowl wrote:
My question is should i just leave one of the batteries constantly in the charger (as it will trickle charge to compensate for the loss of charge over time) or could this damage the Batt over time.
M
Yes it will. It will forget what discharged state is.
arrogantowl wrote:
Regarding the second battery, should i leave it in the discharged state or should i alternate between using this and the first battery. I am not likely to be using the drill all day long so will never require 2 fully charged batteries for 1 particular days work.
M
Alternate and always have a fully charged battery waiting in your box.
arrogantowl wrote:
What sort of period of time should i expect the batt to loose its charge totally after fully charged if left without charging it up?
M
It shuldn't really unless you leave it for months. Ni-Cads are very resilient batteries and can sustain their charge over long periods of time. If you do store your kit away for long periods remove the battery from the drill and it will have more charge in it as the drill simply by being connected will drain the battery.
arrogantowl wrote:Should i completely run down the batt before a re-charge (to prevent the batts memory effect)
M
Yes always flatten a battery before recharging, the occasional quick charge won't kill it, as long as you cycle it at a later stage, flatten to fully recharged and then flatten to fully recharged at least twice in succession.
Easy to discharge them, just give it some work to do until it can't turn the chuck. Your batteries are only 1.3Ah so they won't be too difficult to do but only with a load, don't just sit there with the trigger pressed you've be there all day!
Jaeger.
