it worked faultlessly
decided today to go for 7mmx5.5mm rebate with a newish 2ah battery and it worked well on a 18" x12" on 3 sides
on the third corner where the load is more than doubled it "overloaded" for about 2 mins
now off course you can lightly rout out the corners where the load is 2 or three times as much to negate the load
it cut very clean did not "chatter " or give uneven surface at all as you would think a slow revolving cutter may do
but worked very well
would i chose it as my rebate router perhaps not as i have several 18v routers but as a hinge or other light routing its great
