Should I tile or skim it first
Chrisd
Has thanked: 1 time
Post by Chrisd »
Could i prime the walls and tile over the plaster or attempt to skim it first.
London mike 61
Has thanked: 285 times
Been thanked: 402 times
Re: Should I tile or skim it first
Post by London mike 61 »
Before you make any decisions, read this thread ;
pva-why-you-shouldn-t-use-it-as-a-tilin ... -t168.html
Mike
These users thanked the author London mike 61 for the post:
Chrisd
Chrisd
Has thanked: 1 time
Post by Chrisd »
London mike 61 wrote:Before you make any decisions, read this thread ;
Mike
I've bought some proper bonding solution and tanking kit to do my plaster board behind the shower we had a plasterer look at it and he said he would bond it if tiling and skim if we where painting it but want it right 1st time as don't want to do it again
Has thanked: 1414 times
Been thanked: 4015 times
Depending on your skill level... tiling on an uneven surface requires a lot more care and attention than tiling on a flat surface.
Apart from the normal tiling tools you will need a true and flat batten to check the tiles are all flush to the wall as you go...
