Sent from my SM-G930F using Tapatalk
A-Z CONTENTS | DISCLAIMER | DIY VIDEO | HOME | SAFETY FIRST | FORUM RULES
I'm not sure, been here since we moved in. How could I check?sammy.se wrote:Is there a damp proof membrane on that wall, above ground level?
Sent from my Nexus 5X using Tapatalk
If you look at the brick work under the render, you might see a black line of plastic sandwiched between the bricks horizontally along the length of the building. Old buildings used to use slate (easier to see) and new builds use plastics.mole81 wrote:I'm not sure, been here since we moved in. How could I check?sammy.se wrote:Is there a damp proof membrane on that wall, above ground level?
It's not very big 20 x 12" maybe. No damp internally. Will take off all the loose soon, is it ok leaving the exposed block behind once removed?ahfix wrote:How large is the area? Could it just be that rain water is splashing off the concrete slab on to the wall. Any damp patches internally in the same area?
Try knocking off the render and see what the state of the brick and mortar under it is.
