Dying New Turf? Please Help
Sean2012
Has thanked: 18 times
Post by Sean2012 »
Hi all,
This is the 1st time I have had a garden so just a novice.
Had my garden levelled and returfed 3 days ago but wasnt happy with the turf the contractor used (from B&Q) as you can see in poc 1 it had quite a few brown patches the day it was laid.
3 days on and watering it twice a day (using an oscillating sprinkler) for about 1.5 each time (I make sure the lawn isn't flooded) the lawn has more brown patches (see pic 2 as of day 3) or dying.
The contractor won't answer his phone now.
Can anyone please suggest what can be done to male it look greener.
Day Turf was laid
Day Turf was laid
Day 3
Day 3
Rorschach
Has thanked: 126 times
Been thanked: 1045 times
Post by Rorschach »
Give it a chance, this is about the worst time of year for laying turf, it is really going to struggle with the sun and heat. keep watering and let it recover.
Sean2012 (Tue Jul 30, 2019 7:19 am)
London mike 61
Has thanked: 285 times
Been thanked: 403 times
Post by London mike 61 »
If you laid turf in the spring or autumn ( the right time to do it ) you would have to water the turf for up to two weeks to get it established. This time of year it will take longer because the roots on average go down about three to four inches when turf is established.
Just keep up the watering routine and don’t worry about flooding the lawn, you won’t do any damage and it will help the turf roots.
Mike
These users thanked the author London mike 61 for the post:
Sean2012
Post by Sean2012 »
Rorschach wrote: Tue Jul 30, 2019 5:10 am Give it a chance, this is about the worst time of year for laying turf, it is really going to struggle with the sun and heat. keep watering and let it recover.
I did ask the contractor If i should wait till like autumn but he said it doesn't really matter, should have realized that he just needs to make his money.
Thanks for the reassurance
Sean2012
Post by Sean2012 »
London mike 61 wrote: Tue Jul 30, 2019 7:12 am If you laid turf in the spring or autumn ( the right time to do it ) you would have to water the turf for up to two weeks to get it established. This time of year it will take longer because the roots on average go down about three to four inches when turf is established.
Mike
Thanks for the reassurance Mike
Has thanked: 833 times
Been thanked: 3636 times
A lawn feed might help stimulate growth, that and watering. It will come good in September when grass has a little growth spurt. At the minute the roots have not grown and are only in the turf. During winter the grass roots will take hold in the substrate lawn bed, which I hope they tilled over to promote growth. Worse case you can replace a few turfs if they die back. B&Q is not he best place to buy turf though.
Sean2012 (Tue Jul 30, 2019 7:56 am)
Sean2012
Post by Sean2012 »
dewaltdisney wrote: Tue Jul 30, 2019 7:52 am A lawn feed might help stimulate growth, that and watering. It will come good in September when grass has a little growth spurt. At the minute the roots have not grown and are only in the turf. During winter the grass roots will take hold in the substrate lawn bed, which I hope they tilled over to promote growth. Worse case you can replace a few turfs if they die back. B&Q is not he best place to buy turf though.
Yeah, I read up on the B&Q turf reviews and it was mostly the case of dried turf being delivered. Just watered the lawn this morn n noticed little green sprouts in between the brown patches, is that growth from the turf itself or do you think the turf is being rooted into the soil??
yartin
Has thanked: 145 times
Been thanked: 129 times
Post by yartin »
Unless turf was laid on concrete/slabs, you will be fine with time.
Grass self sows to a certain extent, you can sprinkle a bit of grass seed to help the dry areas. It will take a season at least for the roots to go down. Grass tends to go yellow when it has dried but that does not mean the roots are dead and they recover with water, summer warmth and a bit of feed. Be patient, it will come good.
Sean2012 (Tue Jul 30, 2019 11:44 am)
Sean2012
Post by Sean2012 »
Thanks for the replies. On another note how do I get rid of dead fallen leaves on the new turf. Is it safe to use a rake?
London mike 61
If you have got one , use a proper lawn rake or a stiff broom.
Just one small thing about turf this time of year, when the turf does start to grow don’t set the mower blades too low. Try and keep the grass about 30mm - 40mm long so that the turf isn’t stressed by too much heat and it will also discourage moss developing on bald bits of soil. This may mean you have to mow a bit more often but the area will look lush and green.
Mike
Sean2012 (Tue Jul 30, 2019 1:10 pm)
Sean2012
Post by Sean2012 »
Thanks for the advice Mike.
OchAye
Has thanked: 855 times
Been thanked: 994 times
Post by OchAye »
When you water you need to put down a couple of inches of water (put a jar down and see when it collects as much water). The idea is to get the water to go below the roots so the roots grow downwards looking for the water. Don't just sprinkle the top :-) It will be all right :-)
These users thanked the author OchAye for the post:
Sean2012 (Thu Aug 01, 2019 8:00 am)
Sean2012
Post by Sean2012 »
OchAye wrote: Tue Jul 30, 2019 6:26 pm When you water you need to put down a couple of inches of water (put a jar down and see when it collects as much water). The idea is to get the water to go below the roots so the roots grow downwards looking for the water. Don't just sprinkle the top :-) It will be all right :-)
That is a really good idea, as its quite difficult to tell how much has been watered. :thumbright:
Sean2012
Post by Sean2012 »
Seems a tad bit better than before
Day 6
Day 6
Return to “Gardeners World”
