Kitchen Cupboard Problem
Distorted Vision
Has thanked: 4 times
Been thanked: 7 times
Post by Distorted Vision »
The shelves in one of my kitchen cupboards collapsed. One of the back boards is loose. Is this a job that a joiner can do or do I need a kitchen fitter?
Has thanked: 833 times
Been thanked: 3633 times
The shelf sits on a 34p push in shelf support like these https://www.ebay.co.uk/i/311881524572?chn=ps there will be a hole in the cabinet side for it.
Easy enough to sort yourself. If it is loose wrap some tape around the stud to make a tighter fit.
Distorted Vision
You misunderstood.
The backboard on the left hand side has come out of position. You can see the gap between the two backboards. How do I fix this backboard?
It looked like the shelf is resting on olive oil bottle. To access the back panels will mean taking the cabinet out and this might well be a difficult job to do as this cupboard is clearly part of a run. This monocoque design spreads the loads and holds the cabinet runs firm but it makes it hard to dismantle and you might find difficulty removing pelmets and the like. You need to get the work into perspective, this is one loose shelf in a cupboard that few will see the inside of so I would look to form three support legs out of some wood to hold the shelf up and do not overload the shelf in future.
Distorted Vision
Not a job I wish to undertake myself. Do I need a kitchen fitter or can a joiner do it?
You buy a bit of 2 by 1 wood and cut three equal lengths that you can glue to the back panels and rest the shelf on that. it really is not worth getting a tradesmen in for such a simple job. Go on, you can do it.
Has thanked: 48 times
Been thanked: 2606 times
As dewaltdisney says, it will cost a small fortune to get a trades person to do the job, as to do it properly all of the kitchen units will have to come out, just to access the back, the alternative (again as dewaltdisney says) is to buy a length of 2 x 1 wood cut it into 3 lengths, each just taller than the bottle of O/0 and glue them, one in each corner.
Another idea would be to buy 2 more bottles of O/O and put them in the other two corners and take the shelf support out, so the shelf will rest on the bottles of O/O but I honestly think the timber will be cheaper.
Just checked, yes it will, Tesco 1L of O/O £3 and you need two, wood (stake on google, 99p)
dewaltdisney (Wed Apr 22, 2020 2:27 pm)
OnlineOnline
OchAye
Has thanked: 855 times
Been thanked: 994 times
Post by OchAye »
Distorted Vision wrote: Wed Apr 22, 2020 11:39 am Not a job I wish to undertake myself. Do I need a kitchen fitter or can a joiner do it?
I would not advice you to want the cabinet to be made as good as new, i.e. remove it, rebuilt it, etc, as that could cause more damage. If you are happy with a repair that you will not really see once you got things back in the cabinet, any competent handyman should be able to figure out an easy solution, you do not need a joiner or a kitchen fitter and it would not be worth their while or they would charge you a lot.
Distorted Vision
Heeded dewaltdisney's advice. Used 5 pieces per shelf. Rock solid:
These users thanked the author Distorted Vision for the post:
dewaltdisney (Wed Apr 22, 2020 3:48 pm)
Well done, easily sorted. Thanks for the update. I kind of liked SE's idea of the three Philipo Berio supports :lol:
kjones1829
BANNED
Post by kjones1829 »
It looks pretty solid now. Did you glued it? Hoping that the divider well hold on for long. Maybe, avoid putting heavy items on the top portion.
Distorted Vision wrote: Heeded dewaltdisney's advice. Used 5 pieces per shelf. Rock solid:
Well done you, and to think, you first said
Distorted Vision wrote:Not a job I wish to undertake myself.
Nice, clear in focus pictures too.
OnlineOnline
Distorted Vision
kjones1829 wrote: Wed Apr 22, 2020 4:11 pm It looks pretty solid now. Did you glued it? Hoping that the divider well hold on for long. Maybe, avoid putting heavy items on the top portion.
Yes with Sticks like Sh*t Turbo.
kjones1829
BANNED
Distorted Vision wrote: Wed Apr 22, 2020 4:59 pm
Well, I guess everything is fine then. :)
Return to “Kitchen Fitting”
