- It is currently Mon Apr 21, 2025 1:01 am
Weathershield Quick-Drying Gloss
- Tom d'Angler
- Has thanked: 1142 times
- Been thanked: 553 times
Post by Tom d'Angler »
I've used Weathershield Trade quick-drying gloss (and satin) after the Weathershield quick-drying undercoat several times now and it's always been really good. I used it a couple of weeks ago on a front and back door. The customer left the doors open for at least 7 hours before closing them (I drove past 7 hours after I had finished and I could see the front door was still propped open) but the next morning the doors were sticking. She's only told me about it yesterday so I have only just been to have a look. There are white lines were the doors stuck to the rubber seal and the door was still sticking when I called this evening. The doors are dry and they feel it - no tackiness at all - but, even now, there is a suction between the door and the seal. Could it be a problem with the seal i.e. has it reacted to the paint and deteriorated in some way? The seal isn't sticky at all. Has anyone else experienced this?
Tom d'Angler
- dynamod
- Elephant Man
- Has thanked: 592 times
- Been thanked: 1444 times
A lot of these exterior trim paints are of necessity, flexible and quite 'soft' (for lack of a better word) In that regard, rubber seals don't often do well against them, even if the surface is touch dry. It really depends on how tight the door is when its closed I guess. Removing the draught seal for a day or two, though perhaps a bit drastic, will create the space for the paint to part cure to a sufficient degree without marking.
Rubber/plastic seals around doors, from a decorating point, are a PITA. Much like gripper rods, but I digress.
- These users thanked the author dynamod for the post:
- Tom d'Angler (Wed Sep 01, 2021 3:15 pm)
Nihil expectore in omnibus
dynamod
- Has thanked: 285 times
- Been thanked: 403 times
Post by London mike 61 »
I’ve not used weathershield paint but have used similar water based gloss for that sort of thing and found that if I give the seal a wipe over a couple of times with WD40 the stickiness goes away.
Mike
Mike
- These users thanked the author London mike 61 for the post:
London mike 61
- Tom d'Angler
Thanks both.
I have finally decided: no more outside work! Only had three booked in this year but the weather meant all three had to be re-scheduled several times and this problem with the paint / seal is the last straw.
Tom d'Angler
- dynamod
- Elephant Man
I've been on the fence about outside work for years, for the same reason. It's not that I dislike it, but bad weather can throw a schedule out of sync in a couple of days and you wind up chasing your tail for long enough.
FWIW, I know a few decs that have tried dumping outsides, and it did seem to hurt their work more than expected. If you don't do a lot of exteriors, or your regular customers are loyal enough, it may be feasible.
- Tom d'Angler (Wed Sep 01, 2021 5:29 pm)
dynamod
- Has thanked: 279 times
- Been thanked: 327 times
Post by Desmondo15 »
Had this problem too which is one of many reasons why I don’t do outsides anymore. I’m sure the sunlight strength has changed too.
- These users thanked the author Desmondo15 for the post:
- Tom d'Angler (Tue Sep 07, 2021 2:27 pm)
Desmondo15
When push comes to shove customers aren’t that loyal. You can do your best and go the extra mile but in my experience it’s one sided in the long run. Sad but true. I expect a few will say different imo if they can get someone as good for cheaper etc they will.dynamod wrote: ↑Wed Sep 01, 2021 5:23 pm I've been on the fence about outside work for years, for the same reason. It's not that I dislike it, but bad weather can throw a schedule out of sync in a couple of days and you wind up chasing your tail for long enough.
Desmondo15
- Has thanked: 202 times
- Been thanked: 526 times
I've not experienced the problem myself but have worked with decorators who would give seals a wipe with a vaseline coated rag prior to shutting.
Grendel
- Tom d'Angler
I should have posted an update about this...
I went back a few weeks ago, wiped the seals with a bit of meffs, put tape on them (Q1 Delicate Surface), painted the doors, and told the customer to leave the tape on for a few days if possible and to leave the doors ajar until bedtime. I drove past at 6pm and the front door was already shut tight. (Maybe I should have asked when their bedtime was.) Got a call three days later to say she had removed the tape and the doors aren't sticking any more.
Tom d'Angler
