Are you saying fitting a standard mortise Sashlock lock on the centre line of the mid rail, with a case depth of 64mm and a case height of 109mm. While supposing the mid rail is 200mm and a stile of 125mm and jointed with a basic through tenon or a twin through tenon. Will not damage the integrity of the joint?dirtydeeds wrote:tim
your comments show you know very little about traditional door construction which is little changed in over 400 years
the lock fits between the tennons in the mid rail of a door
which is EXACTLY the reason why the lock is centred in the mid rail
which is EXACTLY why it doesnt damage the integrity of the door
I understand fitting a traditional rim lock or a simple mortise latch may be fitted with out losing to much of the joints integrity constructed with a twin through tenon.
