- It is currently Mon Apr 21, 2025 6:23 pm
Where do you store your paint?
- Argyll
- Has thanked: 1194 times
- Been thanked: 584 times
Last year I lost a new tin of Leyland paint due to frost in my shed. Someone on here told me
If it looks like cheese it's had a freeze
I normally keep my paint/emulsion in my lockup and considered building a large box and insulating it with some Rockwool. I'm just wondering if this is the best option? I can store them in my attic but rather I keep them in my lockup if I can.
Argyll
- aeromech3
- Has thanked: 177 times
- Been thanked: 665 times
Insulation only slows the cooling of contents, if the surrounding temperature is sub zero for long enough the paint will reach that temperature. I used to keep potatoes in deep cloches, so I assume a cellar is more suitable to store paint (as well as wine).
aeromech3
- Has thanked: 126 times
- Been thanked: 1045 times
I keep mine in the house, somewhere where I know it gets colds but never drops to freezing. Insulation is useless without some form of heating. You could make a heated box using a 100W lightbulb and thermostat but easier to stick it at the back of a cupboard in the house.
Rorschach
- Tom d'Angler
- Has thanked: 1142 times
- Been thanked: 553 times
Tom d'Angler
- Has thanked: 285 times
- Been thanked: 403 times
Post by London mike 61 »
I keep mine in the garage , although it’s cold it never freezes in there.
Mike
Mike
London mike 61
- Argyll
Argyll
- Argyll
Argyll
- Argyll
Argyll
- Puma
- Has thanked: 681 times
- Been thanked: 709 times
You can use low wattage cat mat heaters about 20w so it will be about 15 pence per 50 hours of usage and combine it with a thermostatic plug controller so it just switches on at about 5 degrees. Obviously make some sort of box or heap of blankets or whatever to keep the heat in.
Puma
- Has thanked: 118 times
- Been thanked: 21 times
I keep mine in our utility room which I have more or less taken over for the purpose of storing my gear. Only the washer and tumble drier intrude!
Problem is there’s no heating in there and it does get very cold in winter. Haven’t had any paint problems yet, but I’m sure all my power tool batteries (also kept in there) seem to need charging more often in the winter. Haven’t done any scientific checks or anything like that, it’s just a gut feeling.
Croker
- Has thanked: 3 times
- Been thanked: 80 times
Don't forget paint is very inflammable, be very afraid were you store it.
Nos
- Has thanked: 202 times
- Been thanked: 526 times
I keep water based in the garage which gets cold but probably not freezing to any degree and i've had no problems. Oil based is stored in a shed and again no problems. Indeed i've been tidying the garage and used a tin of pea green paint that was at least 40 years old and had been in the shed or a shed for that time to paint the floor with and a tin of blue gloss that was probably the same age to paint a gate with. Both worked like fresh paint.
A few years ago i left a tub of fenceguard outside and it froze solid. Once thawed it seemed to seperate with a watery layer on top. Being a tightwad and not wanting to throw it away i left it in the greenhouse with the top off. The water evaporated leaving a creamy deposit that painted onto timber just fine.
Grendel
- Has thanked: 48 times
- Been thanked: 2608 times
It's also flammable
Thing is that paint itself does not burn easily if at all, it is the solvent that is in the paint that has to be considered, if he is using water based paints, no problem.
It's the solvent vapour that is cause for concern, so, so long as the tubs are closed and sealed no problem.
Most solvents have to get to 100 degrees F (Around 38 degrees C) to ignite, I believe the worry is keeping them above 0 degrees C
