Peeling paint left a messy patch
DearDIYers
Has thanked: 1 time
Post by DearDIYers »
Hi Everyone
We were painting our dining room wall and the existing paint kept peeling off onto the roller. It looks like the previous owners painted straight onto fresh plaster and that's why it was peeling? Anyways, we scraped off as much loose paint as possible which left us with a patch about the size of a watermelon!! We sealed this with a sealant paint. All good so far except when we have painted over the patch you can see the outline so it's not level with the rest of the wall!! What do we do as it looks messy 🙄. Please don't tell me I need to scrape all the paint off, the wall is huge! Thanks for your help 👍
DearDIYers
Has thanked: 1 time
Anyone?
James500
Post by James500 »
Use a filler to level. Easy fill
Or sand to level the paint. Then paint again
bitzz
Has thanked: 10 times
Been thanked: 34 times
Post by bitzz »
Certainly not easy fill, it is too coarse and will fall out. Use a fine surface filler and feather out the edges - prime with watered down emulsion then paint the wall again as normal.
Has thanked: 833 times
Been thanked: 3636 times
And if I may state the obvious, you will need to paint the whole wall, not just the affected area.
DearDIYers
Has thanked: 1 time
Thanks everyone, will give that a go
