- It is currently Tue Apr 08, 2025 2:59 am
Can you suggest a tool to unscrew this
- Has thanked: 45 times
- Been thanked: 7 times
It's circular, it screws off, seems to have 4 notches at 12.3.6 and 9.
I tried with a set of adjustable but it slips Alot and I don't want to wreck them.
It's about 6cm across so my mole grips won't go around it.
Thanks in advance
Thanks in advance
- 20220809_152840.jpg (231.45 KiB) Viewed 879 times
vlb
- Has thanked: 833 times
- Been thanked: 3632 times
Look up pin key spanners. Amazon do an adjustable one for £7.99 depending on the circumference??
- vlb (Tue Aug 09, 2022 7:54 pm)
- Has thanked: 1415 times
- Been thanked: 4031 times
As an alternative to the above suggestion get an old screwdriver and a hammer, gently tap the screwdriver in one of the slots to free it (this assumes you don't want to re-use the fitting)
Thank you both for yiyr reply
The chamber I am trying to remove is filled with bearings so I don't want to bash it around
I will look into the first opte
Thanks a million
Thanks a million
vlb
https://www.amazon.co.uk/QWORK-Adjustab ... DTMW&psc=1
this should do the trick
Thanks for the suggestion mate
vlb
Yes,that will do it
- vlb (Tue Aug 09, 2022 8:22 pm)
- aeromech3
- Has thanked: 177 times
- Been thanked: 665 times
Always used a C spanner, doubt the one you link to is man enough as a mallet touch would be needed on a C spanner; but good ones can be expensive!
aeromech3
I'm reluctant to shock it as the cylinder is full of ball bearings and from what I can see they are already falling out (the reason I am dismantling this is because the rod that runs through the chamber does not run as smooth as it should).
vlb
- aeromech3
Other than soaking in Plus gas you might have to use a slight tapping action, if you look on e-bay there is one C which is up for bidding 99p +delivery.
aeromech3
thanks man, have ordered one of these as a backup
https://www.amazon.co.uk/dp/B00Q4B95ZU? ... yp_imgToDp
seems abit sturdier,
Plus gas is a good shout
Thanks again
vlb
- Has thanked: 10 times
- Been thanked: 194 times
As said a “C” spanner is the correct tool , but expensive.
Undone lots of these types of retainers on bearings over the years , difficult to say how stuck or not it will be.
I would do the following :-
1) clean all around the nut , remove paint and dirt , fine wire brush
2) soak as said with plus gas or the like
3) if you have an old screwdriver with a square section shaft or a piece of bar , cut or grind the end to a slight angle so that it site in the slot neatly and sits on the side flat
4) whack it with a hammer decent shape whacks and am sure it will come loose.
I dare say you will get a new bearing easily from some where like Eriks or some other local bearing supplier.
Chippo1
