Poorly fitting sockets
F20283
Has thanked: 17 times
Post by F20283 »
Hello all.
Looking for some ideas ref poorly fitting sockets/switches mounted very close to each other.
Looked at finger plates but can’t find any to suit this issue.
Don’t really want to interfere with the tiles.
chrrris
Has thanked: 234 times
Been thanked: 410 times
Post by chrrris »
If you loosen the screws on the faceplates, you should find there is about 2 or 3mm of movement, as the brackets on at least one side of the backbox should be floating. So hopefully enough to at least get both faceplates horizontal and in line with each other and the worktop.
It's really the tiling and grouting that look like the issue. Other than fingerplates, the only thing I think you can do is remove the faceplates (with the power off) and try to tdy it up a bit with grout to fill the gaps and even the surface a little.
These users thanked the author chrrris for the post:
OnlyMe (Wed Jun 21, 2023 5:16 pm)
F20283
Post by F20283 »
Thanks. I’ll whip them off and take a look
Return to “Electric Forum UK”
