Brush size
rob39
Has thanked: 2 times
Brush size
Post by rob39 »
Hi all what’s your go to brush size and make, for any particular job such as - panel doors, skirting, cutting in walls, architrave etc
Has thanked: 829 times
Been thanked: 3607 times
Brush size
I use mini rollers, quick and necessary for water based paints as they go off quickly.
rob39 (Thu Oct 26, 2023 7:24 pm)
Grendel
Has thanked: 201 times
Been thanked: 518 times
Brush size
Post by Grendel »
Like dwd I'll use rollers quite often. For actual brushes and sizes that can again depend on the job in hand . For the trim work you mention I tend to use something like a 2" or 2 1 /2" . For walls either a 3" or 4" for the cutting in. I have some smaller brushes and occasionally use a 1" . For my own house I've used a 1 /2" sash brush to paint the mouldings on doors ( white mouldings , grey or black on everything else) . I use a mix of Purdys , Hamilitons and a handful of brushes that have long since lost any makers name but work well and I'm comfortable with them.
A few weeks ago a customer had me painting railings and garden furniture with Rustoleum paint. That has some kind of cellulose thinner if I'm not mistaken so I brought a set of cheap brushes from Home Bargins and used them. The paint seems to hammer the brushes and it was much easier to just throw them away afterwards.
These users thanked the author Grendel for the post:
rob39 (Thu Oct 26, 2023 7:23 pm)
bourbon
Has thanked: 11 times
Been thanked: 19 times
Brush size
Post by bourbon »
Cheapest ones I can find! But as @grendel will attest to, my painting isn't up to much!
Grendel
Brush size
Post by Grendel »
'tis true cheapest bog brushes he can find....
bourbon (Sat Oct 28, 2023 8:00 pm)
