House built in 1991 (Bovis)
Regular block and brick, had cavity wall insulation 5 years ago.
The bedroom above the garage gets a cold floor in winter. The garage ceiling is double skin insulated plasterboard (about 50mm total thickness). But the ceiling / floor joists are empty and end with a vented soffit above the garage door. Cold air enters and travels down the joists cooling the bedroom floor.
I'm prepared to take the bedroom floor up (chipboard). Looking for advice on what steps I can take to add/improve the insulation to this room.
I wonder what kind of inslutation I can put under the bedroom floor? Can I block off the ends of the joists behind the soffit?
What about in the void, and the small wall that runs under the dormer (with radiator on)? I'm prepared to take the rad off to allow a large-ish access hole behind the rad to access this space if need be.
- Ultimate Handyman Forum Index Other DIY Energy Saving
- It is currently Tue Apr 01, 2025 2:25 am
Insulation advice for bedroom above garage
Energy saving questions in here please
meza
- Has thanked: 831 times
- Been thanked: 3627 times
I think the better option would be to take the garage ceiling down and fill it with Celotex from below. Depending on the joist layout you may only have to open one end to slide the insulation in. The chipboard floors will most likely be glued along the board's tongue and grooves (to stop squeaks) so you will muller them trying to pull them up. The plasterboard is easier to replace from below using a deadman. Either direction you will have a fair bit of remedial.
- Has thanked: 1 time
Hi DWD, sorry I should have added that taking down the garage ceiling will be a royal PITA because of the junk in the garage! I'm alright at getting up the chipboard, and it's only nailed and yes it does squeak so I'll be replacing the nails with screws.
So assuming I go in through the top, just PIR will be fine? Fill the whole joist depth? Need the tape anything up? Vapour barrier needed? Cheers!
meza
I would say you need a bit of clearance to allow air to circulate, it has to have a bit of ventilation. The insulation will stop heat loss and cold penetration. Minimal gaps are unlikely to cause a cold spot but you can suss out vulnerable heat loss spots as you go.
- Has thanked: 1415 times
- Been thanked: 4030 times
Don't go the full depth, 50mm or 75mm PIR boards will be enough. You want to keep the airflow beneath the PIR boards. Cut to size using a bread knife to give a snug fit between the joists, level with the top of the joist. no vapour barrier required as the foil face will act as a vapour barrier.
- Has thanked: 740 times
- Been thanked: 2355 times
no expert on this
what are the fire requirements above a garage ??
will this effect what insulation' gaps and plasterboard you choose
It has got the double layer of plasterboard above the garage
- big-all (Thu Feb 01, 2024 11:49 pm)
