1994 Potterton Puma 80 with permanent pilot. A trusty workhorse, but showing signs of age!
Extension due next year so hoping keep it going until then when it'll be all change.
The pilot light has lately been going out quite a lot and I'm trying to get a bit of an understanding myself before calling someone out. The flow switch, which incorporates a diaphragm which activates a micro switch to fire the boiler seems to be working (I can see the spring moving back and forth and the red light on the PCB activates during hot water demand).
Questions:
a) first thoughts are a faulty thermocouple, but I can relight the boiler and the pilot will stay lit for multiple hours before it goes out (often over night). Does the fact that I can relight the boiler pilot mean the thermocouple is fine? Or can carbon deposits cause random failings of thermocouple/pilot?
b) the diverter has a wax assembly within it. I'm pretty confident this is faulty as when heating DHW the radiators slightly heat up! So a new diverter seems required, but my question is, would a slightly faulty diverter valve cause pilot to extinguish? The pilot seems to be going out at some arbitrary time, not upon demand of heating or DHW.... So unsure if it's the culprit.
c) possible fan assembly not working efficiently? Causing cut out?
Thoughts welcome!
Thank you one and all for your help!
Stuart
