Shed Water Ingress
Eah_Dunno
Has thanked: 7 times
Shed Water Ingress
Post by Eah_Dunno »
Hello all
Before I launch into my query I'll list a number of apologies :cb
1) Length of post. I would rather try and give you all the information in one go rather than drip feed.
2) Lack of any technical terms - I ain't no builder/joiner :lol:
Following some wild rain I have noticed some water ingress in my shed.
The shed itself is circa 6 years old and is treated annually with Premier Coatings Wood Preservative. There are no immediate holes or signs of damage to the exterior of the shed.
The shed sits on wooden battons which sit on garden slabs. There is no surrounding vegitation.
To ellaborate on the issue I've attached some photos.
I would also expand on the photos as folllows:
Photo 1: On scraping away some lose stones there doesn't appear to be any drainage. On this basis I thought that the water might be getting soaked up from the ground via the batttons.
Photo 2: This shows that the water ingress appears to be from higher up the shed wall. I believe it is "Tounge and groove" :dunno: I think water may be seeping in from the holes made by the nails when the outer skin was nailed to the internal framework. Given gravity this is simply draining down the frame. What you can't really see here is that there appears to be a very small gap between the outer skin of the shed and the framework. Not sure if this is a contributing factor or not.
Photo 3: This is to show the extent of the distance the water has travelled either being soaked up or running down.
Photo 4: A close up of the holes that I think might be part of the problem. Another apology here as despite numerous attempts I could not get this orientated the correct way :dunno:
I've toyed with the idea of installing shed guttering to try an limit the splashback issue but given that this side of the shed is the only side exposed to the elements, I'm not overly convinced any guttering would help.
The other thought I had was to fill the nail holes with some sort of waterproof sealant. I'm sure I read a silicon based sealant would be best.
Other than that I'm out.
Any thoughts, comments, advice or possible solutions would be gratefully accepted :salute:
Thank you all for taking the time to read and comment.
Has thanked: 833 times
Been thanked: 3632 times
Shed Water Ingress
Invariably it is a roof leak as water will find its way down running rather than dripping. It is possible that the felt has a hole letting through. Have a close look at the roof for anything like a split or a hole. You might find this thread interesting viewtopic.php?t=110117
Eah_Dunno (Mon Oct 21, 2024 10:31 am)
OnlineOnline
Has thanked: 48 times
Been thanked: 2606 times
Shed Water Ingress
We had a roof leak, zinc flashing had failed, water was getting in, running along a joist, where it crossed another joist that is where it was dripping from onto ceiling below and into the room below. My point being that it may not be directly obvious where the water is coming from at first glance.
Oh and to change pictures, see my signature.
Has thanked: 740 times
Been thanked: 2355 times
Shed Water Ingress
i would paint it with something like ducksback as it seals and has a waxy finnish
my thoughts dry the outside 50mm packing tape over the bottom 3 planks nail holes none on the next 3 up alternate tape no tape and see what happens
avoid silicon as it wont take a finnish
Eah_Dunno
Shed Water Ingress
Post by Eah_Dunno »
Hello all
Many thanks for your replies/thoughts :salute:
Dewaltdisney - thank you for the additional info thread. I'm at work just now ( tea break :-) ) but will read up on the thread tonight.
S-E - thank you for the comment and the picture rotation instruction. I've now saved Picsize. No doubt it will only be a matter of time before I have to post here again :lol:
To be honest I never thought of the leak being from the roof. I don't recall seeing any water ingress that high up but to be fair to you both I have never looked. Next time it rains I'll make a note of checking there as you have both suggested.
big-all - nice thinking :thumbright: I never considered that future treatment wouldn't have taken to where silicon had been applied. With the best will in the world, even taking my time, I suspect excess silicon would find it's way to places I don't want it to go :angryfire:
I like the idea of packing tape. Will give that a go.
Thanks again - I'll provide an update in the future.
Return to “General DIY forum”
