Dust extractor adaptor
Ferny1
Has thanked: 69 times
Post by Ferny1 »
Hi all
I am trying to find an adaptor to connect Dewalt flexvolt dust extractor to milwaukee 190mm mitre saw, can anyone help thank you.
Has thanked: 48 times
Been thanked: 2605 times
Doubt you will find an exact one, as there is no call for such a thing. However, if you know someone who has a 3d printer, get one printed or search online for one that will sort of fit yours (I have no idea of its dimensions, and you do not say) and get a rubber tube and some cable ties to connect one to the other.
Has thanked: 740 times
Been thanked: 2355 times
Silicon sealant tube cut length wise then rolled to a taper as required
tape along its length plus Many turns off electrical tape to fit the hose to the tube
if its the 584 vac it has a reversible hose adapter in the flexible hose connection
also rutlands' axminster tools and others do stepped adapters for extraction
https://www.axminstertools.com/instants ... %20adaptor
Ferny1
Post by Ferny1 »
The Milwaukee end is 35mm
measured my dewalt 584 hose inner diameter 45
the adapter that comes with the vac and fits both ways round has external off 30 and 45 and internal 25 and 35
so now need to know iff you have the adapter[it really looks like a normal part off the hose]
what dewalt system do you have and is the 35mm external [male]or internal [female]??
Return to “Tool Talk”
