Thinning and Misting every coat
Taffypainter
Post by Taffypainter »
An old decorating lecturer from college said it wasn't just emulsions indoors or masonry paints he thinned
He would always ease up even finishing coats very slightly for better coverage
What he did feel was that the advice for mist coating was however far too liberal and he would put about a pint , maximum , in 5 litres of matt emulsion to prime plaster
I stick with that , I have seen decorators make a right old mess of misting
Has thanked: 831 times
Been thanked: 3627 times
The results will depend on how much suck there is in the new plaster. If the water is sucked out of the first coat too quickly it will leave the body of the paint not absorbed and not binding properly in part of the areas covered. Future full-strength coats may pull the first coat off. The mist coat is a variable guess and that is why you will see different ratios quoted by different people. Quite frankly anything between 50% and 75% should be safe for most new surfaces as the dilute mix gets pulled into the surface and seals it giving a perfect substrate for the finishing coats. it does not matter that the opacity is not great it is the absorption that is important. Your tutors ratio is around 80% rough maths.
Taffypainter
He's got it just about spot on I think
Summer time can use a bit more thinning in my experience
I have never gone anywhere near 60 percent never mind 50 50
