Cannot fully close a window
jackb
Post by jackb »
Hello everyone,
I have attached two pictures of my window. The problem with it is that I cannot fully close/lock the handle (to the left to horizontal position).
Any idea how to fix this ?
Has thanked: 833 times
Been thanked: 3633 times
If the window is closing fully then it is probably a defective handle. Cheap to replace lots of how to videos on YouTube
jackb
Post by jackb »
Thank you
jackb
Post by jackb »
It turned out the circled part (see in the picture below) doesn't turn enough to fully lock the window (see attachment).
What can I do with it ?
The lock mechanism needs to be changed probably. Have a look at this video https://www.youtube.com/watch?v=D6h5Y85NjWY it could be fiddly if it is upstairs. You can get a UPVC window repair guy into do it if you feel it is too difficult, look on Yell for local firms to you.
Bob225
Has thanked: 106 times
Been thanked: 882 times
Post by Bob225 »
Well there's your problem its not square and it looks like its cracked/split
you will need to remove the mech (espagnolette) from the window and see if it has any maker's marks on it and measure it
jackb
Post by jackb »
It turned out that it is not like in the YT video above. Do I have to replace the whole window or can I just disassemble the mechanism from the window ? Any hint please ?
(I cannot afford any window repair guy atm)
Has thanked: 48 times
Been thanked: 2606 times
jackb wrote: Fri Dec 27, 2024 11:25 amcan I just disassemble the mechanism from the window ?
Probably
jackb wrote: Fri Dec 27, 2024 11:25 amAny hint please ?
Look for a different video on YouTube. Seriously, YT is a wealth of information, you just need to find the right one for you.
The Saracen locks are a bit different see https://www.youtube.com/watch?v=FgQ5GFktzdc I think to remove the lock the two end tabs have to be pushed towards the middle to release the lock (after the handle spindle is removed) I think this is it https://gbdiystore.com/era-saracen-shoo ... gK0aPD_BwE Check the backset measurement before ordering a new one. Yours will be the 11.5 length bolt.
Bob225 (Fri Dec 27, 2024 7:25 pm)
Bob225
Post by Bob225 »
ah its that type that uses 2 locking rods, lock the window open and the rods just twist out, unlock and remove the handle, the lock should pull out
https://www.youtube.com/watch?v=1S9p6VVOrcY
Oh yes, I missed the two rods at the window edges in the picture. That is the one.
Bob225 (Sun Dec 29, 2024 5:41 pm)
Return to “General DIY forum”
