- It is currently Sun Apr 06, 2025 5:51 am
Compressor suddenly stopped working - suggestions?
- Has thanked: 72 times
Post by pjontheroadagain »
Could anyone suggest why my Airmaster Tiger 8/65 'Turbo' compressor has suddenly stopped working?
It was running fine but when I switched it on during the recent cold snap, it ran very slowly for a few seconds then stopped. I wondered if it was because the cold weather had made oil was too to turn over, but just tried it again now it's warmer but its dead.
I've checked the fuse in the plug and the electrical connections under the pressure switch/safety valve (which was replaced a couple of years ago) but can't find anything wrong.
Any suggestions of what else might be at fault?
pjontheroadagain
- Has thanked: 48 times
- Been thanked: 2605 times
I am just wondering has the pressure switch failed? I found a manual on line Click me
- pjontheroadagain (Sat Jan 18, 2025 9:39 am)
Thanks Someone Else
Yes, the new pressure switch was made in China, no doubt from chocolate, so I was going to try swapping it with the old one.
Thanks for the link to the manual.
pjontheroadagain
- Has thanked: 106 times
- Been thanked: 882 times
iirc it has a reset switch for the thermal overload - it's on the motor casing
highlighted in green
- airmaster 8-65.jpg (68.04 KiB) Viewed 313 times
- These users thanked the author Bob225 for the post:
- pjontheroadagain (Wed Feb 05, 2025 11:32 am)
Bob225
- Has thanked: 11 times
- Been thanked: 19 times
try pushing the overload button back in. That's an old compressor, We changed the model number ages ago. All of the pressure switches for small compressors are made in China. Please don't delude yourself thinking otherwise. Are you running it off an extension lead by any chance? The thicker oil is certainly something to consider. First port of call is the reset switch though
- These users thanked the author bourbon for the post:
bourbon
Thanks guys - yes, I tried resetting the overload button but to no avail. I did a continuity test on it, which seemed to suggest it was working.
A friend has sinced tested the capacitor for me and found it seemed to be OK, although apparently the test equipment used very low voltage - not sure if that's conclusive?
No, the compressor was plugged directly into the mains.
pjontheroadagain
Can you turn it over by hand, I take it the oil level is ok
Bob225
Yes, it turns over easily by hand and the oil level is fine. I think the fault lies with the electric motor - I'm hoping that it is either the starter capacitor or the overheat cut-out switch that is at fault but I'm not an expert on these matters!
pjontheroadagain
