- It is currently Thu Apr 03, 2025 8:50 pm
Water leak. Dishwasher tripping RCD
- Has thanked: 1 time
Hi
We had a water leak under sink where dishwasher plug socket is. I fixed the leak but every time I plug the dishwasher in it trips the RCD. But there is no power to the dishwasher. I’ve aerated the cupboard and dried the socket. The socket powers other appliances fine without tripping.
Is the dishwasher fried or can I try anything else to get it working? Trying to get hold of a fuse for the dishwasher plug but not sure that should make a difference? I’ve only had it a year so replacing it will be painful.
Thanks for your time.
bob786
- Has thanked: 48 times
- Been thanked: 2605 times
If the DW trips the RCD, it is probably the DW that has the problem. You could try and leave the DW open to dry out, This leak, did it get into the DW around the back? if it did it may have corroded something.
Was it a cheap DW? wondering if it is worth getting an appliance engineer out to look?
The leak wasn’t directly behind the DW but it’s possible water could have splashed on it?
I’ll maybe pull it out and have a look.I'm just wondering how long I should wait for it to dry before calling someone out. Or whether it’s worth calling someone at all if it’s probably fried?
bob786
Your call.
You have not said how much the DW cost you,
Depends how much a call out is
What really happened with this "splash" (You don't have to lie to me, I am not there, and I am only trying to help YOU)
- Has thanked: 118 times
- Been thanked: 219 times
As a 1 off test try the dishwasher with an extension lead from a different socket circuit
Neelix
- Has thanked: 831 times
- Been thanked: 3630 times
I know very little about electronics but I do know that the control boards are very fragile and I would suspect that the short probably blew the main board in the DW. I think that Neelix's suggestion to try different socket would prove the point. Boards are around £50 to £80 so check your make and decide if that is a way to go. But, as I said, I don't know enough to give proper guidance, I hope you get it sorted.
- BANNED
Post by Peter Johnson »
It sounds frustrating, especially since it's only a year old. Let's see if we can figure out what's going on.
See if the fuse in the plug is blown and replace it if needed. Look for any damage to the plug or dishwasher wiring. Try plugging the dishwasher into a different socket. Make sure everything is completely dry. Check the dishwasher's manual for any reset instructions. Since it's under warranty, contacting customer support might be the best option. If these don't help, consider getting a professional electrician to inspect it.
Peter Johnson
An electrician is no use with a dishwasher. As I suggested it needs an appliance engineer
It has already been suggested to try a different socket
Leaving it to dry out has already been suggested
Who said the dishwasher is under warrantee?
As mentioned there was a leak from one of the sink pipes. The plug and socket which are next to the pipes were wet but the body of the DW is dry. I.e it seems like water only got on the plug rather than any other component or wiring. I’ve tried another device on the socket and that works fine.
It’s a Bosch. £500. Out of warranty (and pretty sure water damage not covered)
Tried on a different circuit with an extension. It trips the RCD every time so can’t get it to power on. Can’t think of any other way to ‘force’ it to power on to check if it is working. By no means an expert but I’m sure the RCD trips for a reason.
So I’m thinking the socket is fine. But it must have gone on the plug and fried it inside?
I think perhaps an appliance engineer is required. Can’t think of anything else I can try.
bob786
You could cut the plug off and fit a new plug. You do seem to have proven its the DW. As for fried, doubtful, but if water got inside (an appliance engineer can confirm by taking it apart) may beat £500 I would get an appliance bod to look, but its your call.
- Approved Electrician
- Has thanked: 225 times
- Been thanked: 664 times
OnlyMe
Hi all. Thanks for the advice.
Bosch came. It was the power cord. Looks like the water must have blown it. Replaced and now working fine.
bob786
Good, I am glad you got it fixed, thanks for the update.
- bob786 (Mon Feb 17, 2025 2:17 pm)
