external wall lights
Locked
time served
Post by time served »
I would like to fit some external sensor lights to the side and rear of my house which can be overridden from a light switch.
If i wire into the existing lighting circuit will i still need to fit a fused spur rated at 5amps because it is suppling external lighting?
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
There is no need to fit a fused spur if it is being wired into the existing lighting circuit, you only need a fused spur and 5 or 3 amp fuse if you are taking the feed from the ring main or similar.
time served
Thanks for confirming my thoughts on the matter.
BTW i ended up ripping down my ceiling so now i have access to all the pipework and eletrics i know i got advised against it but hey lifes what you make!!
merry xmas all.... 8-)
Locked
Return to “Lighting”
