router
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
When you say best, depends what you mean.
Smaller routers are by far and away the best for some jobs, like hinge recesses, small chamfers, use with jigs, big 1/2" ones are too clumsy for some jobs
purplemadboy
Post by purplemadboy »
fair enough..you know more about routers than i do,if you had looked at the link the bumf says it also takes 1/4 collets also..maybe i should have stated that.. ::b
Thanks for the info dave..i looked at that one in B & Q the other day and it seemed good.Nice to hear that it works for what you need it for and it sounds good for me too
If its not broken hit it hard
Has thanked: 740 times
Been thanked: 2355 times
http://cgi.ebay.co.uk/RYOBI-ERT2100-240 ... dZViewItem
ok sorry £110 squid good price :thumbright:
now another fly in the ointment
we need to know what your plans are for the router!!!
if you are planning on moulding and light decorative work like making rustic furniture then1/4" is preferable as they are easier to handle especialy for a beginner
unless your planning on making stair components large moulding or worktops i would consider starting with a 6 to 1100w
purplemadboy wrote:fair enough..you know more about routers than i do,if you had looked at the link the bumf says it also takes 1/4 collets also..maybe i should have stated that.. ::b
all 1/2" routers take 1/4" cutters its the weight and comfort thing
purplemadboy
I have never used a router in my life so this a big step.I understand what you are saying by starting small and getting used to it , but i think that is a money down the drain.
With more power cant I just turn the power down and slow it a wee bit to start with?
As for the comfort thing I totally agree with you,thats why I need as much in as pos because I cannot get my hands on it to try it,as I will buy it over the net and if I return it it would cost me the postage again so I would be £20 down
purplemadboy
ps i would use it for light work to start with
chippymike
Has thanked: 16 times
Been thanked: 9 times
Post by chippymike »
small 1/4 routers that are around 600 w like the trend t3 which i own is perfect for round over, 10x10 chamfers, cutting groves from 6mm - 12mm. and 1/2 1600w router is only really use for big rebates, groves, mortising, cutting work tops. imo they both have there uses depending what you plan to use it for.
purplemadboy wrote:I have never used a router in my life so this a big step.I understand what you are saying by starting small and getting used to it , but i think that is a money down the drain.
would you write a letter with a tin off spray paint :scratch: :scratch:
or cut your cheese with a machettie :shock: :shock:
or go shopping in a dust cart :-P :-P
purplemadboy
ok guys ,I am taking this on board what about the Bosch POF1400AE Router 240V,would this be better for me :scratch:
trust me when you get into routing more than one router is essential
different routers different cutters fitted to save keep changing them :thumbright:
i have around 6 routers i use the hitachi m12v the least its a 1850w big beastie it spends 90% of its time under a router table gathering dust but its there for making hand rails or complicated mouldings with larger cutters or indeed removed for worktops and the like
this £25 powerdevil thats around 8 years old does the most "table" work as its easily portable light and fixes in a workmate :thumbright:
http://s21.photobucket.com/albums/b270/ ... hop009.jpg
at the miniut my ryobi 18v lamin trimmer/router gets most use as its easy to use one handed :thumbright:
i was going to say its the most fun you can have one handed :roll: :roll: :roll:
but not quite :cussing: :thumbright:
purplemadboy
update
Ok Guys ,Iam going for the kill,I am going to buy tomorrow the new Bosch POF1400AE Router 240V http://www.screwfix.com/prods/26549/Pow ... outer-240V
Any thoughts before I dive in....... :welcome:
if you like it go with it :thumbright:
all i will say is its nearly a 1/2 inch size but not quite so you have most of the weight without the versatility :scratch:
perfect light weight starting router size is around 600 to 800w because they will do all the light moulding work easily in one pass and 90% of what a 1400w router will do in one pass in heavier mouldings :scratch:
purplemadboy
:cb :cb :cb :help:
purplemadboy
I have checked the weight of the 1400 ,and its the same as the wee 1100 (3kg).The Ryobi is over 6kg...I will go and see the 1400 tomorrow and get my hands on it and see what I think..will let you know how I get on... :wink:
Hoovie
Borders Bodger
Been thanked: 4 times
Post by Hoovie »
Screwfix have a good returns policy, so if you take care with opening up the package and play around with it WITHOUT a router bit fitted to try and judge the handling without getting it mucked up, you can decide if it is right enough for you.
If you don't like it, just call them up and they will collect it and give a full refund.
Return to “Tool Talk”
