Evolution Rage3 silding mitre saw
You can post and read reviews of all Power tools in here. Tools will be listed by manufacturer, Model number and / or description.please ensure that you put the correct power tool under the correct manufacturer. If the manufacturer is not yet listed then please post in the general part of the power tool review forum.
p4ult
Has thanked: 12 times
Been thanked: 38 times
Post by p4ult »
Had a 10% voucher through the post from Screwfix. Just ordered one of these for 90 quid. [emoji2]
Great video and review
These users thanked the author p4ult for the post:
Has thanked: 1012 times
Been thanked: 918 times
Re: Evolution Rage3 silding mitre saw
Post by ultimatehandyman »
I thought I would add to this thread now that I have a diamond blade for this machine.
As well as cutting masonry it will also cut reinforced concrete such as pre-stressed concrete lintels and also concrete fence posts.
I have to say that I use these machines all the time now when I am making things with wood or metal :wink:
These users thanked the author ultimatehandyman for the post (total 2):
pud1771London mike 61
Rating: 14.29%
London mike 61
Has thanked: 285 times
Been thanked: 402 times
Post by London mike 61 »
Great video as always :thumbright:
These users thanked the author London mike 61 for the post:
pud1771
Has thanked: 102 times
Been thanked: 32 times
Post by pud1771 »
will definitely pick one of them up in the new year when i get the workshop sorted out what dust extraction do you use for it?
I just use a Wickes wet and dry vacuum as it was recommended to me by Razor for general use http://www.wickes.co.uk/Wickes-Wet+Dry- ... r/p/215735
But I upgraded the filter (I am working on a Omni cyclone at the minute) http://www.ebay.co.uk/itm/Wickes-Canist ... XQVERS8mxY
These users thanked the author ultimatehandyman for the post:
pud1771
pud1771
Post by pud1771 »
cheers chez and razor(for showing chez) will pick one of them up as well when i get the saw as seams to handle the dust well :thumbleft:
These users thanked the author pud1771 for the post:
This is the video of it cutting reinforced concrete (The first part of the video is using the Rage 2 with a diamond blade)
Rorschach
Has thanked: 108 times
Been thanked: 1038 times
Post by Rorschach »
How well does the diamond hold up on the steel parts? High speed diamond and steel can be a bad combo.
Rorschach wrote:How well does the diamond hold up on the steel parts? High speed diamond and steel can be a bad combo.
Fine, there was no visible damage to either of the two blades.
Rorschach
I know that the maximum recommended cutting thickness of steel using the Rage 3 S is 6mm, but sometimes you just have to see what it will cut!
Instead of using the Wickes vacuum, I attached a metal ash cleaner/vacuum to the machine to take away some of the swarf.
Has thanked: 735 times
Been thanked: 2339 times
hats off cant fault that performance at all :lol: :huray:
DBT85
Has thanked: 2 times
Been thanked: 11 times
Post by DBT85 »
Just a quickie, but is the sliding mechanism on yours rougher than I feel after a night on the town?
I got a Rage3 from them on their ebay store. £73 for a 10" sliding compound seemed enough to take a chance. Its wonky all to hell and I need to set it up properly, but first off the sliding mechanism seems quite rough. Not having used another I don't know if its normal, but it doesn't seem like it.
p4ult
Post by p4ult »
The sliding action on mine is very smooth. Maybe a clean and a bit of lube is needed?
Paul
DBT85
DBT85 wrote:Just a quickie, but is the sliding mechanism on yours rougher than I feel after a night on the town?
As Paul says. A good clean might fix it, although there is s possibility that the linear bearings are damaged. The slide action should be very smooth.
DBT85
DBT85
Post by DBT85 »
Thanks guys, I'll have a look and sort it out now that I know for sure that its not right.
Return to “Power Tool Reviews”
