Never Ending House Renovation/Extension
- CorradoG60
- Has thanked: 4 times
- Been thanked: 1 time
Re: Never Ending House Renovation/Extension
And here we go, first the wall between toilet and bathroom came out!
Previously looked like...
And then...Also taking up all the wet/damaged floor
- CorradoG60
Here we go, removing the third wall from back of the house (Fourth wall if include wall between bog/bathroom!)
- CorradoG60
- CorradoG60
Notice the mark of the sink on the left, gives an idea of the extension...
- CorradoG60
So here we are looking from old bathroom into new extension, all will become a bedroom with en-suite Fitted the new window. And you can see the new ceiling joists I previously fitted when doing the exterior work/roof. The new ceiling in the extension will float through under the old bathroom ceiling.
Edit: You can also just about make out the 'Wall straps' for the wall plates on the extension. Steel straps basically...
- CorradoG60
Showing the RSJ where the house/bathroom wall used to be.
- CorradoG60
Threw down new boards in the whole lot, one big room now! Old bathroom becoming new bedroom with ensuite to come soon!
Can see where sink used to be on the left wall, and where the original house bathroom ended!
- CorradoG60
Looking from within the extension, alarm box still on the original outside wall Can see how the extension sort of becomes a little wider here too.
- CorradoG60
Starting to add/build the en-suite! Can see the old lone toilet window on the right, and just to the side where the dividing wall was. And then closer to camera, where the end of the bathroom was.
- CorradoG60
- CorradoG60
Back to entrance hallway, Started to build a new step...Note, a little plastering done too.
- CorradoG60
Also had the whole of the old kitchen and new extension/dining area floor asphalted. Loved seeing this done, and made it feel much more like a house again
- BANNED
- Has thanked: 216 times
- Been thanked: 1070 times
- CorradoG60
