New desktop pc..............
Has thanked: 47 times
Been thanked: 2556 times
Looking for a new desktop PC, doesn't need much too fancy, windows 10, 64 bit (Not 100% sure what that is, but this one has it)
USB 3, 500GB hard drive and it must have blue tooth.
I only use it for forums, and social media, (That's why it must have blue tooth, so I can upload pictures from my phone, no cables to worry about)
Looking for recommendations. want to stay under £400
Don't need monitor (or an all in one) NEVER used for gaming
Seen some by some company called Vibox, never heard of them, oh this PC is an ASUS still working but just old.
Any suggestions please. (oh and where to buy)
etaf
Has thanked: 37 times
Been thanked: 146 times
Post by etaf »
Is it on windows 7 ? or older
If its on Windows 10 - why the change
are you in UK, at the moment not many stores open, so would need to be an online order and delivery
I would just make sure you get something like an i3 processor, Some of the cheaper models are quite slow, i have always found this to last quite a while , have some friends and family with machines over 8 years old and still outperform some of the new models
john lewis usually give a longer warranty
Slightly over your budget
https://www.johnlewis.com/lenovo-ideace ... r/p4855933
https://www.johnlewis.com/dell-inspiron ... m/p4895706
Currys
https://www.currys.co.uk/gbuk/computing ... 0-pdt.html
Simple DIYer
Wayne
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Post by aeromech3 »
I would have suggested one from scan.co.uk whom I used to get components for my build years ago, but their cheapest, built, home pc is £399 but does not have an SSD or bluetooth although USB adapters are cheap enough.
Razor
Has thanked: 483 times
Been thanked: 1251 times
Post by Razor »
You might consider just upgrading to an SSD for now. It would give your existing pc a whole new lease of life.
If not Aria.co.uk are very good for prebuilt systems. Your budget should get you a solid performing lowish model. If you want to go 4k display you'll need one with a half decent graphics card
Thanks EVERY ONE
I shall have to give it some more thought. Lots too look at.
aeromech3
Post by aeromech3 »
From your request I also checked my PC and found no Bluetooth hardware, Linux Mint op system, and so I bought a 'Plugable' bluetooth USB adapter which clearly said was compatible with recent versions of Linux, such a small device but it worked fine, came with a CD for W XP,7,8,10.
Cable still much easier/faster.
sx_turbo
Has thanked: 17 times
Been thanked: 25 times
Post by sx_turbo »
as razor said what's the specs of your current computer?
You might be best just buying and installing a SSD drive.
My laptop used to take a good 10 minutes to get fully operational, and it was a good spec, intel core i5, 16gb of ram etc. It is now 7-8 years old
I put the SSD in and my word it's like a brand new computer, there is no waiting for anything any more.
sammy.se
Has thanked: 90 times
Been thanked: 80 times
Post by sammy.se »
eBuyer.co.uk is good - I have used them many times before, and have a great selection of pre-built PCs.
LaptopsDirect.co.uk is good - they also sell Desktop PCs. I just bought a computer from them couple weeks ago.
Argyll
Has thanked: 1180 times
Been thanked: 576 times
Post by Argyll »
sx_turbo wrote: Tue Apr 07, 2020 7:32 pm as razor said what's the specs of your current computer?
You might be best just buying and installing a <span class="skimwords-potential">SSD drive</span><span style="position: absolute;"></span><span style="position: absolute;"></span>.
My PC is around the same age. I was thinking of doing the same and putting in more RAM but the ballache of installing everything again puts me off. Is there software that lets me clone everything?
Has thanked: 807 times
Been thanked: 3496 times
My office PC, which I do not use too much now, was a refurb from PC world. It is an HP Compaq with the usual stuff on it and it cost about £200 at the time. I looked inside it recently and found there was hardly anything in it, in fact it looked like a laptop board and the rest of the cabinet was empty. A bit like having a barn for a rabbit.
The point I am making is that the refurbished PC's might be worth considering.
sx_turbo
Post by sx_turbo »
Argyll wrote: Wed Apr 08, 2020 9:36 am
yes
https://www.currys.co.uk/gbuk/computing ... 6-pdt.html
just buy a hardrive, use the above and hey presto.
These users thanked the author sx_turbo for the post:
Argyll (Wed Apr 08, 2020 10:55 am)
yartin
Has thanked: 144 times
Been thanked: 124 times
Post by yartin »
It depends what you want to use it for.
An intel i5 based PC, 8GB RAM and SSD hard disk will suffice most applications including browsing and video streaming. Wifi, usb, graphics, bluetooth...etc come standard.
Argyll
Post by Argyll »
sx_turbo wrote: Wed Apr 08, 2020 10:12 am
yes
<a href="https://www.currys.co.uk/gbuk/computing ... 6-pdt.html" class="skimlinks-unlinked" data-skimwords-word="https%3A%2F%2Fwww.currys.co.uk%2Fgbuk%2Fcomputing-accessories%2Fcomponents-upgrades%2Fprocessors%2Fpny-2-5-ssd-enclosure-upgrade-kit-22082146-pdt.html" data-skim-creative="500005" title="" style="">https://www.currys.co.uk/gbuk/computing ... dt.html</a>
What exactly is this? Is it a cradle for holding the SSD and the software disc?
sx_turbo
Post by sx_turbo »
Argyll wrote: Wed Apr 08, 2020 1:00 pm
yes
yes,
you transfer the files using the software to the ssd, then remove from the external case and install into the laptop/pc. it should then be as was before the swap, albeit a darn site faster.
Argyll (Wed Apr 08, 2020 5:32 pm)
aeromech3
Post by aeromech3 »
SX-turbo, I would be very interested to learn if acronis can copy the operating system, this needs to be burnt as an ISO if I remember?
Whilst SSD are a big improvement over HDD, the operating system is usually the bug**r that slows with age not the HDD, IMO.
Return to “Computers”
