Are these switches still available?
Posted: Sat Apr 11, 2020 6:30 am
by Rorschach
It's a 2 way switch used on a landing, as you can see there isn't room for a standard switch.
Posted: Sat Apr 11, 2020 6:53 am
by ayjay
I think they're known as Architrave switches (if that helps a search).
Posted: Sat Apr 11, 2020 7:04 am
by Rorschach
Ah yes that does help. I had no idea what to search for, amazing how easy it is when you have the right search term!
Posted: Sat Apr 11, 2020 8:06 am
by camallison
I saw some in the Screwfix catalogue I think. Worth a look.
Colin
Posted: Sat Apr 11, 2020 8:16 am
by dewaltdisney
Oh yes, I had to look, but I am sure R has found them already
https://www.screwfix.com/p/crabtree-ins ... hite/271hv
Posted: Sat Apr 11, 2020 9:48 am
by Rorschach
Ooof screwfix are pricey!
We are hoping that the old one will come up ok when cleaned, need to get the awful labels off etc. Before potentially making the problem worse though I wanted to check I could buy a replacement if needed.
Ebay came up as best price with postage etc. £4 delivered. They are only £2 on an electrical retailer site but the postage is high unless you spend a minimum amount. £4 is absolutely fine though, assuming we need it.
Posted: Sat Apr 11, 2020 9:53 am
by Chippo1
I normally take the switch or socket off, then clean using Jiff and a greenee
Then set aside in a warm place to throughly dry and refit
Posted: Sat Apr 11, 2020 11:41 am
by Bob225
beleive or not WD40 has is uses - removing glue and labels is one of them
Posted: Sat Apr 11, 2020 1:30 pm
by Rorschach
Bob225 wrote: ↑Sat Apr 11, 2020 11:41 am
That was going to be my first attempt, I use it for a lot of cleaning.
